Author Topic: How to best convert an ac compressor to a air compressor  (Read 6248 times)
Jeeper_will
« on: February 16, 2009, 02:27:32 PM »
Anyone have info on the best inexspensive way to build an onboard air system out of your exsisting ac compressor? I hear this is pretty common and not to difficult to accomplish but havent actually seen it done. Any helps appreciated. Thanks again guys!
Offline VA_YJ
  • Now I need a CJ...
Re: How to best convert an ac compressor to a air compressor
« Reply #1 on: February 18, 2009, 03:02:44 PM »
Check this out, lots of good links:
http://www.jedi.com/obiwan/jeep/yorkair.html
« Reply #2 on: February 18, 2009, 03:38:09 PM »
If you have a OEM Sanden compressor then you'll want to run an inline oiler ion the input since these compressors don't run with a separate oil slump.  You'll also need to run an inline oil/air separator on the outlet so your air isn't all oily.  Wire the clutch to a switch then to a 12v source so you can turn on and off the compressor at will.
Really there isn't much to it.
« Reply #3 on: February 18, 2009, 11:43:01 PM »
You can use your OEM compressor for air, here's a pic from Kilby of the common items included in an OBA system:
