Author Topic: guage cluster  (Read 5244 times)
guage cluster
« on: February 18, 2009, 09:47:49 AM »
my gauge cluster on my 1990 yj has been bombarded with water resulting in the connections corroding away. i know they make a kit so you can install regular gauges but i don't really have the $$$$ right now to spend on gauges and would rather go with a cheaper solution. i came across a gauge cluster from a 1988 yj that is supposedly in good condition... only problem is that its from a 6cyl. anyone know if the gauge cluster is compatible between the 6cyl and the 4banger by chance? i know the 6cly was carb and my 4banger is efi but figured id ask to see if this could be my be my solution.
Re: guage cluster
« Reply #1 on: February 18, 2009, 01:14:38 PM »
from looking at what wiring diagrams i could find and then finding the parts catalog it looks like they are the same for 4cyl or 6cyl... aka they are listed as the same part number. so I think ill go for it and hopefully have functional gauges.
ChuckC806
Re: guage cluster
« Reply #2 on: February 18, 2010, 08:53:25 PM »
how did this work out for you? i have a '99 XJ with the idiot lights, and was wanting to swap out to the gauge cluster.  i've scoured the junkyards, but can't find a 4banger with them.  only 6cyl.  let me know.
Re: guage cluster
« Reply #3 on: February 18, 2010, 09:04:22 PM »
um. from looking at the parts cataloge from jeep the gauge cluster had the same part number so i think they are the same.. but the cluster was sold before i got a hold of the seller. that was for a yj though and a xj will be a completely different cluster obviously..
« Last Edit: February 18, 2010, 09:04:37 PM by chardrc »
ChuckC806
Re: guage cluster
« Reply #4 on: February 18, 2010, 09:09:44 PM »
no doubt it'll be different.  like i said though, i was lookin to see if the cluster from a 6cyl would match up to the 4banger for a swap.
Re: guage cluster
« Reply #5 on: February 18, 2010, 09:20:59 PM »
The tach is different from 4 to 6.
Re: guage cluster
« Reply #6 on: February 19, 2010, 07:18:51 AM »
I wonder if you had them side by side if there is a jumper or trace that gets cut to make the tack a 4 or 6 cylinder unit??
TrailsLessTaken
Re: guage cluster
« Reply #7 on: February 19, 2010, 07:45:59 AM »
I might still have the tach from my gauge swap, Its from a 91 YJ I dont know if it would work or not.  If I can find it youre welcome to it
Re: guage cluster
« Reply #8 on: February 19, 2010, 08:35:13 AM »
there might be a pot/trimmer that you adjust to calibrate the tach somewhere inside on the pcb (not talking about the aftermarket newer ones with the switch on the backside)
radark1
Re: guage cluster
« Reply #9 on: February 19, 2010, 04:32:03 PM »
Send me a PM and I will send you a spare that I have. Merry Christmas.
ChuckC806
Re: guage cluster
« Reply #10 on: February 24, 2010, 06:03:34 PM »
Just out of curiousity, say I did find a cluster to swap out...The mileage is digital, so I were to swap one out, would it show my actual mileage or would it show the mileage from donor?
Re: guage cluster
« Reply #11 on: February 24, 2010, 08:45:37 PM »
anyone know if a gauge cluster from a mpi yj would work in a tbi yj? i know the center gauge on the tib is a clock and on the mpi it has the 4wd light, but other than that would the actually gauges work / have the same range for inputs?
Re: guage cluster
« Reply #12 on: February 24, 2010, 08:50:59 PM »
I'm curious as well, I'd rather have the clock
Re: guage cluster
« Reply #13 on: February 24, 2010, 09:23:19 PM »
if the connector is the same and has the same pinout
the voltmeter will work
the water temp and oil gauge are dependent on the senders, so if they're the same it will work if not you need the senders (i think the oil pressure sender is different)
the gas tank sender should be the same (i assume) - but if it is different this one is the biggest challenge
the clock needs a permanent 12v which i'm not sure if it's available on the YJ cluster connector
Re: guage cluster
« Reply #14 on: February 24, 2010, 09:34:17 PM »
I doubt the pin out is the same
