Author Topic: stalls in rev  (Read 3035 times)
dbr5010
stalls in rev
« on: March 01, 2009, 02:20:05 PM »
I have did some searches and cant find much ,i got a 95 yj 3 speed at 4cly . I pulled someone out awile back and had to snach hard to get them out and the next day started haveing problems , i can go from n to r and it starts to shake alittle from p to r it shakes and cuts off when i am driving and come to a stop i have to keep my foot on the gas and brake to keep it going . So far i have clean the tb and a new iacv and no luck any idea will help thanks.
Re: stalls in rev
« Reply #1 on: March 01, 2009, 03:36:01 PM »
you sure it's not a trans problem
dbr5010
Re: stalls in rev
« Reply #2 on: March 01, 2009, 08:26:45 PM »
I dont know for sure what it is just tring everything no code or lights on . When i go from p to r i can keep it going with some gas .
Re: stalls in rev
« Reply #3 on: March 01, 2009, 08:57:40 PM »
doesn't do it in drive?
dbr5010
Re: stalls in rev
« Reply #4 on: March 02, 2009, 05:24:04 AM »
It shakes some but stays running
Re: stalls in rev
« Reply #5 on: March 03, 2009, 12:37:24 PM »
How does it idle in Neutral?
dbr5010
Re: stalls in rev
« Reply #6 on: March 03, 2009, 05:11:40 PM »
It idles good in  all gears just one i shift them it starts to shake , could it be in the tranny you think .
Re: stalls in rev
« Reply #7 on: March 03, 2009, 05:17:02 PM »
I'm going to say probably yes but would have to check it out live to know for sure..
Re: stalls in rev
« Reply #8 on: March 03, 2009, 05:41:31 PM »
Here is a simple check jack the rear wheels up put it on jackstands for the safety consious, make sure its in 2 wheel drive and try tha same routine if it still shakes and stalls its engine related
Re: stalls in rev
« Reply #9 on: March 03, 2009, 06:20:03 PM »
When you used the snatch strap, did you pull from the front or back?
I'm thinking the problem is in the drivetrain someplace.  You'll have to localize it to the transmission or transfer case or axles.
Easy way to check the transmission is to put the transfer case in Neutral and then shift through the gears.  You'll need to jack it up to check the transfer and axle.
dbr5010
Re: stalls in rev
« Reply #10 on: March 03, 2009, 06:43:39 PM »
I hooked up in the front and went in rev , i got a tps today to try it  going one thing to another il try jacking it . Off topic what size screw is in the tps to the tb , i stip it trying to get it out brfore dark and where can i get one hardware or what .
Re: stalls in rev
« Reply #11 on: March 03, 2009, 07:37:39 PM »
 :uhoh:  That's not the proper way to strapping.  It's a good way to break gears.
I'm not sure if a TPS still help.  Id you disconnect your TPS, the engine will not idle until it's warned up.  You would have to stay on the throttle to baby it.  If it was the CPS, the ending wouldn't start and might die all of a sudden.
Not sure on the screw.  Take the good one and measure it.  It could be Metric.
dbr5010
Re: stalls in rev
« Reply #12 on: March 03, 2009, 08:36:17 PM »
1200 to rebuild it i think i need it any way whats better buy one from advance auto and pay 200 to put it in or rebuild it for 1200 ?
