Author Topic: dana300  (Read 2840 times)
drunkencityworker
dana300
« on: March 31, 2009, 04:10:02 PM »
will a twin stick dana 300 that used to be behind an ax15 and nv355 work on my rh30
Re: dana300
« Reply #1 on: March 31, 2009, 04:28:06 PM »
The D300 will bolt to an AX15 with adapter or a NV3550.  You'll need to swap your D30 out though.  A lot of work just to get a D300 in there.  You'll probably have to reroute your exhaust as well.
I think it's better to go with a Ford D20 so you won't have to change out the front axle.
Re: dana300
« Reply #2 on: March 31, 2009, 04:28:33 PM »
The D300 has a 23 spline input. Not sure what the output on the RH30 is. You will also need a passanger drop front axle. Unless you flip the D300.
Mr_Random
Re: dana300
« Reply #3 on: March 31, 2009, 11:26:42 PM »
The key words are "used to be behind an ax-15."
If the 30rh is 23 spline (probably, I think all 91+ trannies are 23 spline), then the d300 (if already flipped with a kit) should bolt right to it, but you'll still need new driveshafts and shifter linkage.
If you have some fabrication skills, there are writeups on how to make your own d300 flip kit, but if you're lucky the PO already installed one!
drunkencityworker
Re: dana300
« Reply #4 on: April 01, 2009, 06:51:12 AM »
he said it was clocked for a tj. Does that mean it was flipped.
drunkencityworker
Re: dana300
« Reply #5 on: April 01, 2009, 06:52:21 AM »
anybody know what spline count I have
Re: dana300
« Reply #6 on: April 01, 2009, 08:39:02 AM »
Won't know until you tell us what you're working on.
Re: dana300
« Reply #7 on: April 01, 2009, 08:58:19 AM »
RH30 = TF999 = 23 spline
Re: dana300
« Reply #8 on: April 01, 2009, 09:05:02 AM »
They were all 23 spline?
drunkencityworker
Re: dana300
« Reply #9 on: April 01, 2009, 02:03:52 PM »
thanks old jeeper. sorry I have 95yj 4cl auto. I asked him if its pass drop or drivers.
Re: dana300
« Reply #10 on: April 01, 2009, 02:29:53 PM »
D300 are all driver's drop as far as I know. Need a flip kit to replace the 231.
Mr_Random
Re: dana300
« Reply #11 on: April 01, 2009, 05:17:47 PM »
But the guy said it was clocked for a tj, so chances are it IS drivers side drop.
Good luck dude!
drunkencityworker
Re: dana300
« Reply #12 on: April 01, 2009, 05:18:34 PM »
what all does the flip kit entail? does anyone have a link to a write up?
Re: dana300
« Reply #13 on: April 01, 2009, 08:33:58 PM »
http://www.downeastoffroad.com/miva/merchant.mvc?Screen=CTGY&Store_Code=DEO&Category_Code=tc
Not sure if there is a write up or not, but these guy's make a flip kit.
