Author Topic: O2 Sensor need  (Read 1941 times)
Bton
O2 Sensor need
« on: April 28, 2009, 02:18:46 PM »
Anyone have a O2 sensor out there.  I have a 92 with the pacesetter header and the O2 sensor is junk from my last header burning out.  It's the sensor closest to the manifold.  I have no catalytic converter.
Re: O2 Sensor need
« Reply #1 on: April 28, 2009, 04:42:30 PM »
You'll probably want to buy one instead of hoping someone had a used one as they do require replacing over time.
On a YJ there is only one O2 sensor.  It does not matter what is or isn't downstream from it.
A new sensor will probably be around $50.
melbill
Re: O2 Sensor need
« Reply #2 on: April 28, 2009, 05:03:32 PM »
$45.00 at Autozone I'm going to get one Thursday night after I get paid.
Bton
Re: O2 Sensor need
« Reply #3 on: April 29, 2009, 09:12:29 AM »
yeah I but the dust and bought one. I can't believe how bad the jeep runs without it, but then again I do have the 19# injectors so it's already running lean
Bikerjr1
Re: O2 Sensor need
« Reply #4 on: April 29, 2009, 12:32:36 PM »
Why would it run lean if you changed out to the #19 injectors ?
I thought the computer and sensors could compensate for this and other changes.
JR
Re: O2 Sensor need
« Reply #5 on: April 29, 2009, 12:38:50 PM »
if you added 19# injectors you would have more fuel vus being rich not lean. the is until the computer adjusts of course.
Re: O2 Sensor need
« Reply #6 on: April 29, 2009, 01:39:10 PM »
I have had the 19H injectors, and never had a problem with running lean in over a year and a half I have had it...
