Author Topic: quick question. 98 tj 2.5 transsfer to a 95 yj 2.5?  (Read 2593 times)
tallrugbyguy
« on: May 24, 2009, 11:40:41 AM »
have a chance to pick up a 2.5 out of a 98 tj to fit into a 95 yj. im think they are compatible- am i correct?
Re: quick question. 98 tj 2.5 transsfer to a 95 yj 2.5?
« Reply #1 on: May 24, 2009, 12:53:03 PM »
Yes, but the fuel rails are different so keep the YJ setup.
There's a chance belt routing may be different, late '95 YJ's are the same as a TJ and early '95s are like the earlier YJ's.
« Reply #2 on: May 24, 2009, 01:26:08 PM »
The Cam's are a bit different as well.  Should drop in and bolt up though.  Swap over your old fuel rail and it should be good.
« Last Edit: May 24, 2009, 01:26:32 PM by Jeffy »
tallrugbyguy
« Reply #3 on: May 25, 2009, 11:17:54 AM »
ok, well i was thinking about buying it and getting it rebuilt, so cams and such should be ok. as well my jeep is a later yj. so in theroy it should be fine? just double checking.
« Reply #4 on: May 25, 2009, 03:50:23 PM »
If it's cheap and in good shape buy it already.  You can work around everything else.
lanulos89
« Reply #5 on: May 26, 2009, 05:41:04 PM »
i went the other way around put my 95's in my 98 , intake was diff, oil pressure sensor and the pickup coil and motor mounts, and t stat housing otherwise all the same
tallrugbyguy
« Reply #6 on: May 27, 2009, 12:44:46 AM »
thx guys.
lanulos89
« Reply #7 on: May 27, 2009, 05:53:21 PM »
u will be lossing 3 hp btw just saying lol
