Author Topic: timing  (Read 1619 times)
tjjohn
timing
« on: June 29, 2009, 02:52:13 PM »
can or how can i adjust the timing on my 1998 2.5
Re: timing
« Reply #1 on: June 29, 2009, 03:07:26 PM »
You can't.
Re: timing
« Reply #2 on: June 29, 2009, 03:51:50 PM »
Well, you can by modifying your CPS.  This will give you a few degrees, tops.  Distributor should be keyed to go in 0* or 180* so you can adjust the timing the normal way.
Re: timing
« Reply #3 on: June 29, 2009, 08:07:11 PM »
Jeffy,
Could you explain how it works please and how's the camshaft position sensor fitting in the picture? thanks.
Re: timing
« Reply #4 on: June 29, 2009, 08:30:00 PM »
Jeffy,
It's not the Camshaft but the Crank Shaft Position Sensor.  The computer watches the crank to know where the pistons are.  Advance the CPS and the computer will think the marks are coming up faster or slower then normal.
