Author Topic: Best $200 you've spent on your jeep  (Read 5307 times)
Re: Best $200 you've spent on your jeep
« Reply #15 on: September 10, 2009, 05:27:10 PM »
ew how did i forget.. i wanted to line my interior after welding in the new floorpan...  :clap:.. now you've got me dreaming
« Reply #16 on: September 10, 2009, 09:17:47 PM »
thought i remembered someone mentioning they wanted to line the interior after i posted that i had done mine..guess it was you lol. go with herculiner if ur gonna do it...dont cheap out with rustoleum.
drunkencityworker
« Reply #17 on: September 10, 2009, 09:52:59 PM »
think its pontiac sunfire seats that bolt in. jesse james has em. locrite for dana 35 fit and work in dana 30. same spline count just no c clips
« Reply #18 on: September 10, 2009, 10:03:41 PM »
Hell, just take the seats out of your dad's Rubicon.  Personally, I'd probably try to get late model TJ seats since they are pretty nice.  Old Camaro seats were popular but that was back a few years.  Anything from the 80's or even the early 90's is gonna smell and probably be in sad shape.  The other problem is that most seats these day's are designed for large people.  Nothing against them but when you want to drive aggressively a park bench isn't the best seat.  The other problem is if you have a center console.  Most seats are too wide to use with a large console.  So keep that in mind.  If you're not that picky, then you can go with Cavalier/Sunfire seats or probably Cobalt.  Some people have used Mustang seats but they're on the wide side.
If I was looking for OE seats, I'd probably look for an Evo with Recaro's to snag.  Maybe STi seats but those are a bit wider and flatter even though they're Recaro's as well but they're not going to be cheap either.  Hell, jsut buy from Mastercrafts and put it on dad's CC.
  • Poseur Extraordinaire®
« Reply #19 on: September 11, 2009, 07:31:57 AM »
I don't think I've ever bought anything for less than $200 for my Jeep... :fitz:
« Reply #20 on: September 11, 2009, 08:20:55 AM »
where did you here that? they have different part #s... they even have different part numbers between the one for the d35 in my 1990 and for the d35 in the 97 gc this one was gong to go into. i just want to make sure it would actually work before taking stuff apart.
« Last Edit: September 11, 2009, 08:21:54 AM by chardrc »
« Reply #21 on: September 11, 2009, 08:51:46 AM »
Best $200 you've spent on your jeep:
there are a few things that i can probably list that were up to $200 but the last one that fits this profile would be the 2 core radiator with aluminum tanks + related: rad $139, lincoln e-fan $30, stainless overflow tank $35 (ok, $5 over the budget but close enough).
drunkencityworker
« Reply #22 on: September 12, 2009, 08:37:40 AM »
d35 locrite into d30. www.gljt.org  then click on gljt on left under home. forum should pop up click it. then goto tech write up. i think its under eliminate vac disco or solid shaft. sorry no link
drunkencityworker
« Reply #23 on: September 12, 2009, 08:40:45 AM »
i am still stuck using phone for net. sorry. Truth did the write up and he is a prof mechanic. He doubted but cooter(knows his stuff) told him it would work and it did
drunkencityworker
« Reply #24 on: September 12, 2009, 08:42:39 AM »
towards end of thread there is a part number for a seal that fits right in and it works great have it on mine.
« Reply #25 on: September 12, 2009, 01:56:37 PM »
thanks for the thread location. thread was easy enough to find... now i just need to decide if i want to go 1 piece axle for passenger side and eliminate the posi loc...
drunkencityworker
« Reply #26 on: September 12, 2009, 02:13:09 PM »
my understanding is if you put locker in front w/o eliminating disco you will pull to the left in 2wd. My reason was since i am opening it up might as well do it cause its stronger.
« Reply #27 on: September 12, 2009, 03:19:45 PM »
ya it is the while you are at it type thing... shouldn't realy pull to the side as it wont be powered but it will have the resistance of turning the diff and drive shaft which i wouldn't think would pull you around very much but i could be wrong.....
drunkencityworker
« Reply #28 on: September 12, 2009, 05:11:32 PM »
I dont notice anything in 2hi. I am in chicago and 4hi in winter will be fun to get used to in winter=-)
