Author Topic: Cheapest way to improve breaking  (Read 7973 times)
  • 4BangerJP.com® Donator
Re: Cheapest way to improve breaking
« Reply #15 on: October 01, 2009, 08:35:19 PM »
Hawk pads (the green ones; LTS?)
I had a set of hawk pads and they pretty much "ate" the stock rotors I had on the front end.  But those pads did work well while the rotors lasted.  Of course this was on a pretty stock jeep on stock AT rubber and the Jeep probably weighed in at 3500lbs with driver.
Your 4 banger all set up with the bumpers, winch, 33" spare, the whole deal has got to weight close to 2+ tons w/driver.  That and the bigger tires are probably working the brakes pretty well.
But it could be a deal where the Hawk pads don't like the rotors you have. I think I have read of rotor/pad compatibility problems.
« Reply #16 on: October 01, 2009, 09:22:18 PM »
http://4bangerjp.com/forums/index.php/topic,3480.0.html
Yeah, I'm betting rotor/pad compatibility has something to do with it (based on looking back at the old post above).  If Brembo rotors, then Brembo pads and so forth.
You can bed the pads correctly, but if there's any incompatibility with the material formulations for your rotors and for the pads, then you can apparently have problems.  Search around on rotor/pad compatibility problems despite bedding.
I'd probably start from scratch on the whole deal -- maybe just do EBC truck pads/rotors or Performance Friction pads/rotors and I guarantee you won't make your braking any worse  :lol:  I'd probably also have a shop do the work and see if you can pick up some tips along the way if they notice you did something wrong the first go around.
« Last Edit: October 01, 2009, 09:35:16 PM by chrisfranklin »
« Reply #17 on: October 01, 2009, 10:35:18 PM »
I ran the Performance Friction pads on my D30. The brake system was otherwise stock. I could lock up the fronts on dry pavement during hard braking. When I was on 35's. I'd like to change my current pads over to the PF pads. I can't lock the fronts now at all even with bigger calipers and rotors, but then the tires are bigger too.
« Reply #18 on: October 01, 2009, 11:50:55 PM »
Hmm, I've locked my brakes up and I'm still running stock front pads.
Actually, I was going to mention this last week but didn't bother.  I was driving down a road in town that passes under the freeway.  There is a T intersection on the right for those coming off the freeway.  This dumbass though he didn't need to stop and darted out as I was less then three car lengths away.  I was doing 40mph maybe.  He was oblivious till he checked his sides again then was a deer in headlights.  Initially he  :eek:  but then kept going.  I was able to hit the brakes and started to lock up the front.  The rear was starting  to come around a little.  I was able to use that and shoot for the gap behind him.  I think the other driver was a bit scared since he pulled over.  I just drove home.   :lol:  The next day I saw my skid mark was around 4ft long but pretty light.  As I heard the tires, I was already letting up.  I'm glad I don't have ABS.  I would have been into the side of him for sure.  Not having the ABS gave me enough time for opening to clear.
I'd like to upgrade all of my brakes, hopefully with larger axles, and do a 1T hydroboost.  The downside to hydroboost is that if the engien dies you have even less brakes then you would with the vacuum system.  Some hydro boost pumps have a reserve so you have a few pumps before they die completely.  It's not fun to drive down roads without brakes.  BTDT, it was raining hard and at night with no lights...   :eek:
« Reply #19 on: October 02, 2009, 05:09:54 AM »
The GM hydroboost unit has a gas accumulator on it that will give you a couple of brake applications after the engine dies. It's the little round can that sits on the drivers side of the unit
« Reply #20 on: October 02, 2009, 05:49:16 AM »
Mercury Marquis master cylinder ($13) and an 8.8 with disc brakes allow me to lock up 35's with no problems.
« Reply #21 on: October 02, 2009, 07:06:06 AM »
what happens if you leave it in gear, wouldn't that turn the pump over? would you still have breakes in that case? (assuming you're rolling still). i guess the question is if you are almost stopped or on the trail on a steep incline, that could be scary though, the vac drum would still hold about 3 pumps, not sure what the accumulator on the hydroboost would do (maybe Sean can give some insight since he is running one).
« Reply #22 on: October 02, 2009, 08:01:46 AM »
Actually, I feel that at high speed, the brakes work fairly well; it is at low speed that I feel they do not bite enough.  At high speeds, I cannot lock them, but I do hear the tires chirping, so any more power and I would lock them (which is not necessarily good).  But at low speed, the Jeep rolls a bit too long, and I dont feel the brakes really grab enough.  I may start with the master and booster and go from there, but I defenetly need to do SOMETHING...  Although maybe Hydroboost is not a bad option either.
« Reply #23 on: October 02, 2009, 08:31:07 AM »
Probably not an option in the US but here in Mexico (maybe Costa Rica and Panama too) asbestos brake pads will allow you to lock up with very little pressure.  My rear axle came with those and it would lock up all the time, way before the front (with modern pads).  Now, with modern pads in back as well, they brake well enough and the rear never locks up.  Overall it is much safer this way.
This reminds me of the weak non-power brakes on the '43 GPW I used to own.  I just realized they where designed to work with asbestos pads back in those days and the braking was very likely much better.
DodgeMudder
« Reply #24 on: October 02, 2009, 08:37:24 AM »
« Reply #25 on: October 02, 2009, 08:48:53 AM »
If Jeffy, 4BangerYj have/had 35s and are locking their fronts with stock or performance friction pads, I don't think boost would be the issue I'd be looking at if high/low speed braking was a problem on 33s.  I'd be looking at the pads/rotors.   But it's not my nickel and who wouldn't like more boost in the long run    :lol:
« Last Edit: October 02, 2009, 08:49:55 AM by chrisfranklin »
drunkencityworker
« Reply #26 on: October 02, 2009, 09:13:27 AM »
can u send me some abspesdos brake pads for dana 30 and 8.8 if they really do grab better
DodgeMudder
« Reply #27 on: October 02, 2009, 09:25:27 AM »
Hmmm I don't know what happened to everything I typed in that post so I'm going to try again, lol
This statement has me curious.  If the brakes can almost lock up the tires at higher speeds but then don't stop well at lower speeds, this sounds more like a break fade issue than a bad brake issue.
When you first start out and everything is cold (not after the Jeep sat for a month don't want to mix rusty rotors into this issue) does the brakes work good?
Does the feeling of not having enough brakes only come around after you just used your brakes hard or for a prolonged period of time?
Do you hover your left foot over the brake pedal while your driving around?
« Reply #28 on: October 02, 2009, 09:42:56 AM »
it's on the list of dangerous materials that cannot be shipped to the US i believe (i'm pretty sure it is for Canada), just a heads-up - not sure how that would work but i'd be careful. they also tend to wear the disks faster. the good pads are fine you need more braking power due to larger tires (for example if you have 33'' tires you will need either 17% larger disks to be same as stock but that is in case they would fit inside the rim, or improved clamping power but i have no idea how much more since i don't think it's a linear increase there - something to do with friction, diameter, temperature and clamping force)
drunkencityworker
« Reply #29 on: October 02, 2009, 10:33:05 AM »
how does wj steering give you bigger brakes. i have heard of v8 zj steering swap but not wj. enlighten me
