Author Topic: Cheapest way to improve breaking  (Read 7950 times)
Re: Cheapest way to improve breaking
« Reply #30 on: October 02, 2009, 11:06:40 AM »
how does wj steering give you bigger brakes. i have heard of v8 zj steering swap but not wj. enlighten me
i think this is the link with the info - http://www.4x4wire.com/jeep/tech/brakes/xj_wjbrakes03/index.htm
« Reply #31 on: October 02, 2009, 11:45:23 AM »
can u send me some abspesdos brake pads for dana 30 and 8.8 if they really do grab better
I'm pretty sure it would be illegal to use them in the US.  I don't even use them here anymore (I could put them on all 4 wheels to even things out and they would work fine) because the stuff is dangerous to breath if you need to fix your own brakes.  But they do grab a lot better based on my personal use of them.
« Reply #32 on: October 02, 2009, 11:50:01 AM »
Actually, I feel that at high speed, the brakes work fairly well; it is at low speed that I feel they do not bite enough.  At high speeds, I cannot lock them, but I do hear the tires chirping, so any more power and I would lock them (which is not necessarily good).  But at low speed, the Jeep rolls a bit too long, and I dont feel the brakes really grab enough.  I may start with the master and booster and go from there, but I defenetly need to do SOMETHING...  Although maybe Hydroboost is not a bad option either.
If the tires begin to chirp then you're locking them up.  It doesn't really make sense that they would work well at high speeds and not a low.  Do you mean, you apply the brakes at high speeds then continue to hold them to stop, but they won't bite once you slow down?  If that's the case then that's brake fade.
BTW: stay away from brake pads that say long life or high mileage as they aren't going to work as well.  Although, on the flip side, performance brakes tend not to last as long.
« Reply #33 on: October 02, 2009, 01:59:51 PM »
I wonder if the added weight of some of your upgrades are making it feel like your brakes are not working right?
