Author Topic: Issues with 19# injector swap  (Read 25617 times)
Re: Issues with 19# injector swap
« Reply #75 on: October 22, 2009, 02:32:08 PM »
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=280412162235&viewitem=&_trkparms=tab%3DWatching
They show PICS of the testing in this auction.
yeah - you can do the same thing, like i said one at a time - you don't need to do them all together as long as you make sure your battery is charged and hooked up to a good charger your pump should deliver the same pressure between runs.
« Reply #76 on: October 29, 2009, 07:31:59 PM »
http://fordfuelinjection.com/?p=82
I might try this. I don't have a spare harness to get a connector from but cleaning them out and new filters wouldn't hurt.
« Reply #77 on: October 29, 2009, 08:31:43 PM »
that won't hurt - you can also try to send fuel backwards thru them but you need to keep the injector open.
« Reply #78 on: November 05, 2009, 06:43:05 PM »
Well I soaked the injectors in Sea Foam overnight. I was expecting to see some fuel injector skeleton's when I checked them in the morning.  :lol:
Or atleast some dirty fluid. It looked real clean. So I put some brake cleaner in thru the filter side and blew it out with compressed air. I noticed on a couple of them the brake cleaner sat in the filter basket and took a bit of time to soak thru. You could see some air bubbles come up as it soaked in. Maybe it was these that caused all my issues.
So I swapped them in and fired it up. It started and ran normal thru the warm up cycle. No CEL! :doggy:
I have not had a chance to get it out on the road but at least it idled normal.
« Reply #79 on: November 05, 2009, 08:46:18 PM »
If they were that plugged now that you have the diagnosis, I'd have them professionally cleaned.
I've had it done for < 90 bucks. Used ones may have the same issues so I have them cleaned.
Just a thought.
« Reply #80 on: November 05, 2009, 10:03:43 PM »
Just a thought.
Ya I don't have alot of confidince in them. There is a local place that will clean, replace O rings and filters and check flow rate for $15@
When you gonna do a build thread on your Jeep? I'd like to see and hear more about it.
What # injectors are you running? 21#?
« Reply #81 on: November 05, 2009, 10:20:07 PM »
Lol, I actually don't know at the moment, I had the factory set running at 45 lbs pressure plug up while
on a hunting trip right after I rebuilt the motor., so I bought a set at a shop in the middle of nowhere
off an engine sitting in their shop. Its been running so good since then I am almost scared to touch them..
I have a writeup somewhere....  Gotta find it its more than I want to re-type... :)
« Reply #82 on: November 18, 2009, 09:30:02 AM »
<a href="http://www.youtube.com/v/VFJlTfHyrUk&amp;color1" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/VFJlTfHyrUk&amp;color1</a>
I saw this on another forum. Thought it was pretty cool.
When I cleaned mine with brake cleaner I did not get this kind of spray pattern. They are cleaner atleast it runs without issues.
« Reply #83 on: November 18, 2009, 12:22:59 PM »
You probably didn't get a spray pattern because you didn't have any pressure.  The guy is pressurizing the syringe with the carb cleaner which is why it dribbles out at times when there is no/low pressure.
« Reply #84 on: November 18, 2009, 12:51:46 PM »
That and I didn't have the electrical connector thingy he made to click the injector open and closed.
« Reply #85 on: November 18, 2009, 03:38:10 PM »
Scott, I have a champion injector cleaning setup you are more than welcome to use cleans the injectors on the engine works fairly well
« Reply #86 on: November 18, 2009, 04:32:53 PM »
Thanks for the offer Art, I think I am OK for now. It runs like it did before I swapped the injectors. So I think I got most of the crud out. I am thinking just because I have it, running a can of Sea Foam in the gas tank. I soaked the injectors in the Sea Foam overnight so there is alot leftover. I guess it wouldn't hurt.
« Reply #87 on: November 18, 2009, 07:00:48 PM »
if it runs fine don't do it
« Reply #88 on: November 18, 2009, 08:21:35 PM »
Yeah, if it's running fine then it doesn't need it.  Who knows you might break them again.  :wall:
« Last Edit: November 19, 2009, 12:44:01 PM by Jeffy »
« Reply #89 on: November 18, 2009, 09:49:39 PM »
Yeah, if it's running find then it doesn't need it.  Who know's you might break them again.  :wall:
 :roflol: Seems like I could break an anvil at times. I think every project I have done I've run into trouble. But that's how you learn.
