Author Topic: 4Banger Jeep Speed (Ha! :)  (Read 31313 times)
Re: 4Banger Jeep Speed (Ha! :)
« Reply #75 on: November 03, 2009, 08:20:31 PM »
Anywhere in particular you recommend getting it from?  I will definatly do it as the jeep gets driven quite frequently,  seems the 89 model speedo gear is tough to find, every part place I go to has it for cj's and 91 and up...
The long and short shaft are interchangeable on the gears, I may be able to set you up if you know what gear you need.
vprsrul
« Reply #76 on: November 04, 2009, 07:40:34 AM »
I used the thread in faq and found that I needed the 36 tooth, but from other sites it says the 35 tooth....
« Reply #77 on: November 04, 2009, 05:49:34 PM »
I have a 35.
vprsrul
« Reply #78 on: November 05, 2009, 04:23:21 PM »
I have a 35.
I am pretty sure that is what i need, i will go out and actually measure the tire tomorrow.
« Reply #79 on: November 05, 2009, 05:23:55 PM »
Speedometer gears aren't an exact science since tires can vary even when the sidewalls say the same size.  I have adjusted some of the numbers that I have actually tried.  Still, any chart should get you without 5mph of 'prefect'.  Mine is currently for all intensive purposes dead on.
vprsrul
« Reply #80 on: November 05, 2009, 07:49:23 PM »
yes sir, exactly why I am going to take the good ole tape measure to my tires!!
vprsrul
« Reply #81 on: November 11, 2009, 07:01:25 PM »
I have a 35.
the outer diameter of my tire is 32 inches.
