Author Topic: Not getting a reading on my speedometer...  (Read 2085 times)
C.Redbeardd
« on: November 03, 2009, 06:39:41 PM »
Hey guys,
So before my transfer case in the YJ blew up the speedo was working perfectly, but once I got the new one in the speedo wasnt working. From what I understand from some people is that the speedo cable isnt connected to the transfer case correctly. Does that sound correct?
Re: Not getting a reading on my speedometer...
« Reply #1 on: November 03, 2009, 07:33:45 PM »
Follow the directions on this link to ensure that the speed sensor is correctly clocked in the tailshaft housing of the transfer case. http://www.4x4xplor.com/speedo.html
« Reply #2 on: November 03, 2009, 08:44:48 PM »
You mean this one isn't any good?  http://4bangerjp.com/forums/index.php/topic,731.0.html    :whistle:
Hey guys,
You have a '90 so, your speedoemter is just a mechanical sender to the gauge and isn't electronic.  You will want to make sure the sender, cable and gauge are OK.
« Last Edit: November 03, 2009, 08:46:31 PM by Jeffy »
C.Redbeardd
« Reply #3 on: November 04, 2009, 12:36:24 AM »
The cable should be fine, I didnt replace that. I just heard that I may not have attached the cabe right. Anywho, I'll check it out. Thanks.
C.Redbeardd
« Reply #4 on: November 04, 2009, 12:38:28 AM »
I've also been relying mostly on my GPS for my speed recently. haha. Anyway, thanks for the advice.
1ATony
« Reply #5 on: November 04, 2009, 08:33:55 AM »
welcome to the site.
« Reply #6 on: November 04, 2009, 08:40:16 AM »
Make sure you have the housing turned to the right tooth count; I did not do this once, and the speedo gear fell into the TC, and got no speedo reading as a result.
  • 4BangerJP.comŪ Donator
« Reply #7 on: November 04, 2009, 09:09:53 AM »
Yeah, you have to look at the teeth range on the VSS and then position the teeth numbering on the sensor directly over a little metal nub that should be down there at 6 o'clock on the transfer case VSS opening.  I had to feel around for the nub after cleaning off the area.  But it's there.  And I got the speedo working right away.
Sorry your's is a different engine year
« Last Edit: November 04, 2009, 09:11:02 AM by chrisfranklin »
« Reply #8 on: November 04, 2009, 09:24:00 AM »
i believe you were right, all years have that for gear alignment, maybe the position of that little bump/mark is different but it's there - i discovered that when i put the '81 CJ Dana 300 in and i could use the speedo sensor and gear off my '95 YJ NP231 and once i aligned the speedo gear housing with the mark it worked like a charm.
