Author Topic: Crawl Box?  (Read 4941 times)
C.Redbeardd
Crawl Box?
« on: November 14, 2009, 07:07:54 PM »
Anyone know much about building  a crawl box(dual transfer case) for the np231? Im interested in this mod, but cant find any good how to guides.
Re: Crawl Box?
« Reply #1 on: November 14, 2009, 07:22:49 PM »
Look on Pirate, a fellow sells a kit there to join 2 231 transfer cases together
Re: Crawl Box?
« Reply #2 on: November 14, 2009, 08:48:16 PM »
Re: Crawl Box?
« Reply #3 on: November 14, 2009, 08:56:22 PM »
http://www.pirate4x4.com/articles/productreviews/mad_rooster
Bounty,
is he still making these kits? And do you know if it works with the Rubicon t-case? Thanks in advance
Re: Crawl Box?
« Reply #4 on: November 14, 2009, 09:00:06 PM »
I have no idea, and 4:1 isn't deep enough for you?
Booty fab doubler: http://www.pirate4x4.com/forum/showthread.php?p=2983930&mode=threaded&highlight=doubler+np231
D.D. Machine was making a good 231/231 doubler that appeared better and cheaper than the MadRooster setup, but I can't find anything on it anymore.
Re: Crawl Box?
« Reply #5 on: November 14, 2009, 10:45:59 PM »
i want to use the rubicon for the crawler box (i have a dana 300) - just so i get 3 different ratios
he's gone, not sure if he still makes them, read some posts that he was hard to get hold of and nobody was able to get the kit anymore from him
Re: Crawl Box?
« Reply #6 on: November 15, 2009, 12:42:34 AM »
You'd be better off using the Rubicon NVG241OR as the transfer case and using the NVG231J as the crawler.
« Last Edit: November 15, 2009, 12:42:49 AM by Jeffy »
Re: Crawl Box?
« Reply #7 on: November 15, 2009, 07:53:32 AM »
One of these?  I built a Box4Rocks when I originally built my YJ.  Even with the motor pushed forward 7" I didn't like the driveline length that I wound up with.
« Last Edit: November 15, 2009, 07:56:06 AM by oldjeep »
Re: Crawl Box?
« Reply #8 on: November 15, 2009, 08:37:34 AM »
What's the low ratio on a d300?  Using the 241OR may just get you a 4spd transfer case, but what a waste of an expensive Rubi box that would be.
Re: Crawl Box?
« Reply #9 on: November 15, 2009, 09:00:02 AM »
i believe it's 2.6:1 or something close to that. Just thinking about it as if I want to get a 4:1 kit for the 231 or the 300 would probably get the price to the same level as using the Rubi one which is a 4:1, and if you find one with the chain busted could be cheaper - i don't have a rubicon t-case laying around :)
EDIT: i also wonder if the reduction gear from the rubi t-case would fit in a plain 231 (could be larger diameter), I saw one with a broken case at some point, not sure if the wrecker has it still
« Last Edit: November 15, 2009, 09:12:55 AM by sharpxmen »
Re: Crawl Box?
« Reply #11 on: November 15, 2009, 10:07:42 AM »
found this on e-bay - i believe it's 4x4 machine
http://cgi.ebay.com/ebaymotors/doubler-crawlbox-NP-231-box4rocks-kit-jeep-Klune-V_W0QQitemZ160375745537QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item255723ac01
It's from Duffy
Cut and paste from Ebay ad.
np 231 crawl box "doubler kit"
This is a simple kit that takes a np231 tranfer case and makes a low cost crawl box out of it, It uses the front half of a np231 case that you provide and in about a hour or so of work you can have a crawl box that will lower your gearing 2.73 to 1 . Just take a 231 case with the right input shaft to fit your trans output and pull it apart , lay the big plate on the casting and mark it were to cut, then file or grind the block off plate to fit, tig weld the block off plate and thats it The kit is made in house on CNC equipment out of 6061-T6 alum and the mid shaft is 4340 cromo steel thats been through hardened. Well I make these in lots of spline counts I only offer 23 spline kits on ebay, so you can mount a Dana 300 flipped or non flipped as the T case or use a second np231 as the T case. there is a lot of info on line under my shops name D.D.Machine and under the product name box4rocks. Thanks D.D.Machine
Re: Crawl Box?
« Reply #12 on: November 15, 2009, 10:10:24 AM »
I gotta say the easiest and shortest overall product is gonna be the Klune. But they are expensive compaired to the others. But good driveline angles have their value.
Re: Crawl Box?
« Reply #13 on: November 15, 2009, 10:16:08 AM »
4x4machine.com is D&D - but their website is long gone.   Good kit, everything fit nicely - you do need to find someone to weld the aluminum cap plate in if you don't have aluminum welding capability.
Re: Crawl Box?
« Reply #14 on: November 15, 2009, 10:34:27 AM »
This Klune still looks for sale. Pretty good deal for $850.
http://www.jeepforum.com/forum/f126/4-1-klune-david-853990/
Just saying...
