Author Topic: Replacement Injectors  (Read 4527 times)
OSO
« on: November 25, 2009, 12:28:45 PM »
Where can I get refurb(Ford!?) fuel injectors for my 2.5?  I am a little skeptical of the junkyard ones from what I have read on some threads.  Also, which ones do I order?
Thanks.
TrailsLessTaken
Re: Replacement Injectors
« Reply #1 on: November 25, 2009, 01:30:10 PM »
You can get them off ebay, if you dont want to do the junkyard deal... but they are both still used.  What kind of jeep do you have?
roksld13
« Reply #2 on: December 01, 2009, 12:10:10 PM »
I want to know the same Question, What do i need for my 2.5L.  I have a 97 tj, geared 4.88, 4.0 tb and tbs, banks header, cat back, arb safari snorkel w/ k&n filter, and synthetic lub.  I want to know what kind of injectors do i need for mine? i dont understand the whole scale!
« Reply #3 on: December 01, 2009, 12:23:22 PM »
I have a known good working set of stock injectors for a YJ. PM me if interested.
roksld13
« Reply #4 on: December 01, 2009, 02:25:26 PM »
are the yj injectors better than the factory tj, i though that it was the other way around? like i said i do not know anything about which injector to use and whats better for my application.  i did read jeffys thread about them but did not get what i need to apply to my jeep (1997 TJ 2.5L). So i guess what im trying to say is my injectors work fine but i want improvement, so what do i need to do that? I know how to change injectors and everything just dont know what applicatiion i need for improvement with out going to summit racing and spending a fortune! sorry if it sound jumbled
« Reply #5 on: December 01, 2009, 02:54:43 PM »
Look for some Ford 24# injectors. Design III with the 4 hole pintle. They come up on ebay. Prices vary. I would suggest cleaning them before installing, so you don't go thru the mess I went thru.
« Reply #6 on: December 01, 2009, 03:03:22 PM »
you cannot use YJ injectors in a TJ - the YJ ones flow too little compared to the TJ ones even at the increased 49psi pressure:
YJ - 17.4lb/hr@39psi,
TJ - 23.2lb/hr@49psi
YJ injector on TJ  - 19.5lb/hr@49psi (quite short of 23.2 which is what you should have at the minimum).
roksld13
« Reply #7 on: December 02, 2009, 05:46:07 AM »
thats what i though from reading jeffys thread, so where should i get my injectors from, what other type car?
« Reply #8 on: December 02, 2009, 01:24:39 PM »
Low mileage Fords.  You can find them on ebay fairly easily.  I'd look for clean one as they are most likely in better shape.  My first set were from a Mustang.  The second set were from a F150...  Go with the Design II's as they are better.  Even Mustang guy's swap their Design I's for II's.
« Reply #9 on: December 02, 2009, 02:56:24 PM »
i think he was asking what p/n or flow (he's got a TJ).
roksld13
« Reply #10 on: December 02, 2009, 04:08:22 PM »
well yes i was asking p/n and flow but the ford thing def help get me closer to the answer i was looking for thanks. so ford design IIs.  Now what flow?
« Reply #11 on: December 02, 2009, 04:08:39 PM »
Well, I'd go by colors since they are easy to spot then to dick around with p/n's.  Do a search on ebay and look for blue (Navagator), white (F-series) or black (Mustang Cobra).  Then confirm them with a bit of searching.
roksld13
« Reply #12 on: December 02, 2009, 06:54:11 PM »
I realize that but what flow and i have searched and your thread is very complex in explination.
roksld13
« Reply #13 on: December 02, 2009, 06:59:27 PM »
I found some black mustang ones that are 80#, Blue ones that are 39#, Light blue ones that are 24#, and yellow that are 19#. Im guessing the 24# or the 39# right, i know 80 # and 19 are not the right way, to much and to little.
roksld13
« Reply #14 on: December 02, 2009, 07:05:28 PM »
i also found some ford 24# bosch racing injectors design III for 64 bucks.  But the factory tj is 23# so is that that much better?
