Author Topic: 4 Link anyone?  (Read 3775 times)
YJ KiD
4 Link anyone?
« on: November 27, 2009, 10:19:34 PM »
does anyone have a 4-link coil setup on their rig i am thinking of possibly doing one on my rig but i am not having much luck finding out the particulars of how to set one up, i understand the concept but am not finding what are the optimal length for the links and the angles that i should be shooting for for it to wrk properly.  i am not opposed to buying some sort of kit with the brackets and such but if i can find all the info i need i can make them myself as i work at a sheetmetal shop with all of the equipment available to me.  Any direction u can point me into or knowledge u may have on the subject will be much appreciated.
Thanks in advance
man i seem to be clueless lately on this stuff i'm not that dumb really i'm not
Re: 4 Link anyone?
« Reply #1 on: November 28, 2009, 01:24:48 AM »
Flyin High used to sell a kit for YJ's, Their pics and drawings were pretty good on line.
Theie kit though is about 7K by the time you buy all the toys...
I have a local shop that does that kind of work, 4 links with massive coil over shocks etc.
He told me he has yet to find a kit that is any easier than just fabbing the parts.
The trick is can you build it so all the joints move in the same arcs so there is not much binding....?
Re: 4 Link anyone?
« Reply #2 on: November 28, 2009, 08:26:51 AM »
i think Jesse-James has some info in the projects section on how he did his rear axle coil conversion - he used TJ coil springs i believe.
Re: 4 Link anyone?
« Reply #3 on: November 28, 2009, 10:06:20 PM »
Gen-Right sells a kit.  It's not 100% bolt-on though.  It just gives you the arms and mounts and you have to locate them.
YJ KiD
Re: 4 Link anyone?
« Reply #4 on: November 29, 2009, 03:19:46 PM »
thanks the gen right kit is just what i was looking for something that has the geometry basically figured and  a good starting point
Re: 4 Link anyone?
« Reply #5 on: November 29, 2009, 04:57:50 PM »
I bought my axle with the truss, crossmember and tabs done already. Just widened the tabs for Johnny Joints, made the links, and hung it. Here's some pics though....
http://s68.photobucket.com/albums/i33/jlafaive/4%20link/
YJ KiD
Re: 4 Link anyone?
« Reply #6 on: November 29, 2009, 07:49:54 PM »
looks good man it is alittle in the future tho i am planning on swapping to an 8.8 and a 44 in front to get my weak axle issues resolved before start on the suspension and it seems to that to do it how i want to do it is goning to be a slightly pricey project but i only want to do it once so i have nothin but time. . . . .i guess
Re: 4 Link anyone?
« Reply #7 on: November 29, 2009, 10:32:05 PM »
Always cheaper to do it right the first time.
Here's a flex shot from this weekend for ya'
YJ KiD
Re: 4 Link anyone?
« Reply #8 on: November 29, 2009, 10:43:52 PM »
what did u use for springs and shocks on the rear i was looking at king coilovers but they are alittle rich for my blood but they all seem to be about the same price for a full coilover with 14-16 in of travel.  What are u using to limit your axle drop do you have limiting straps on it somewhere or are your shocks just fully extending and limiting the axle movement?
« Last Edit: November 29, 2009, 10:49:47 PM by YJ KiD »
Re: 4 Link anyone?
« Reply #9 on: November 29, 2009, 10:52:46 PM »
Stock TJ rear coils, I have a set of rubi springs going in soon though for a bit higher spring rate. Shocks are Skyjacker Hydro's from their scratch&dent Ebay store.
Re: 4 Link anyone?
« Reply #10 on: November 30, 2009, 07:01:06 AM »
Here is a nice 4-link article if you can custom build what you are wanting.
Other interesting articles
PDF file
From AZCrawler
YJ KiD
Re: 4 Link anyone?
« Reply #11 on: November 30, 2009, 03:38:07 PM »
exactly what i was looking for the basic layout that i needed thanks alot guys
Offline VA_YJ
  • Now I need a CJ...
Re: 4 Link anyone?
« Reply #12 on: December 01, 2009, 02:50:46 PM »
I'm installing a Clayton kit on my TJ.  They have some DIY parts as well - frame brackets, axle trusses, tube ends, johnny joints, etc.  This is weld on, not bolt on.
www.claytonoffroad.com
