Author Topic: Taurus Fan Wiring  (Read 2145 times)
OSO
Taurus Fan Wiring
« on: December 01, 2009, 05:07:20 PM »
Where can I find a Keyed connector to hook up the thermostat controlled switch for the fan?  Is there one in the connector box next to the battery? Or do I have to go back to the fuse box under the dash?  Thanks for any info.
Re: Taurus Fan Wiring
« Reply #1 on: December 01, 2009, 05:25:05 PM »
didn't understand the question OSO: do you have some pics of your thermostat or what are you trying to install (a link or product description)?
OSO
« Reply #2 on: December 01, 2009, 08:03:13 PM »
Hey sharpxmen,
I have one lead that goes to the the battery(+), I have another lead that needs to be hooked up to a "keyed" source, so the fan only works when the ignition is on.
Thanks
« Reply #3 on: December 01, 2009, 08:06:26 PM »
It depends on what you want to do.  I have my keyed source off the fuse box under the dash since I'm running a switch as well.  There is a keyed source in the power distribution box but you'll have to double check which spot it's in with a FSM.
« Reply #4 on: December 01, 2009, 11:36:58 PM »
Hey sharpxmen,
Thanks
oh, i see - somehow i didn't understand what you meant by keyed - i thought you want a "keyed" slot to put your relay - you obviously meant a 12v contact feed. check the FSM for a source for that (like Jeffy said) - from memory i can think of the asd command feed (solenoid side) that is powered when the contact is on (same for the fuel pump relay) - they are both fused so that's a good thing. if you don't have AC you might be able to use an existing relay slot as well, but i cannot remember if that's at the PDC by the battery or the inside fuse block. I believe that some models also had an ABS relay which can be used as well if you don't have ABS, although i am not sure if that is wired or not.
OSO
« Reply #5 on: December 02, 2009, 10:28:05 AM »
Thanks Guys for the input, it helped.
« Reply #6 on: December 04, 2009, 04:40:53 PM »
In a '94, both the AC and ABS are in the PDC...  Don't know which Jeep you have, though.
