Author Topic: Air Pressure for BFG A/T 33X12.50  (Read 2886 times)
Offline mrcabinet
« on: December 10, 2009, 02:53:29 PM »
Just curious as to what others are running. I've been experimenting, going from 25 psi to 34 psi. Right now they're at 28 psi, which seems to feel fairly decent.
Re: Air Pressure for BFG A/T 33X12.50
« Reply #1 on: December 10, 2009, 02:57:38 PM »
I did a chalk test on mine, but when I ran 33's I ran 28.
« Reply #2 on: December 10, 2009, 03:13:01 PM »
i found that 31 psi works best for me but i have M/Ts so that could be different and i also have 10'' wide rims and the tire sits flat anyway so could be different if the rim is narrower.
« Reply #3 on: December 10, 2009, 03:32:43 PM »
33X12.5 KM2's MT on 8" wheels; 28 also works for me.
« Reply #4 on: December 10, 2009, 05:27:58 PM »
33 X 12.5 15 KMs on 7 inch rims at 25 psi.
Offline mrcabinet
« Reply #5 on: December 11, 2009, 10:29:29 AM »
Thanks for you replies!
25 was too soft and 34 was too hard for me. At 28 the front still seems to drag a little bit while turning so, since I have 10" rims I think I'll give 30 or 31 a try.
« Reply #6 on: December 11, 2009, 11:06:45 AM »
At 28, I do feel it takes a fraction of a second for the Jeep to turn when I am driving and suddenly turn the wheel...  But more pressure, and the ride becomes too stiff for my taste
« Reply #7 on: December 11, 2009, 12:03:17 PM »
Remember to set the pressure cold, and occasionally check it hot. I have found some AT tires do heat up a lot, I end up adjusting tire pressure based on weather and driving conditions and mission of the day :) For instance if I'm headed down the freeway and I know its going to be hot, I usually start at my base pressure and bleed a couple pounds off if its going to be a multi day / many hour freeway burn. I try and keep the working pressure under 35 on my Toyo's. Other wise I need new fillings at the end of the day since they are 10Ply load range E  :yikes:
Offline mrcabinet
« Reply #8 on: December 15, 2009, 08:28:53 AM »
Well, it turns out that my old tire pressure gauge was off by about four pounds (low). I found out when I used a friend's fancy schmansy digital gauge. 28 was actually closer to 24 and 34 was more like 30. I took the pressure up to 33 and man, what a difference! The ride is a tad stiff, but driveability on the freeway is 10 times better. No more wallowing around or drag when I turn the wheel!
