Author Topic: Which winch did we get?  (Read 5164 times)
czjeeper
« on: December 29, 2009, 07:03:01 PM »
My brother just picked up a '93 YJ.
In the box of parts we got, there was this:
It's a Warn, but what is it?
Obviously we need a cable. Where is the best place to get that?
The roller fairlead is still mounted to the winch plate on the Jeep.
What else do we need?
Thanks!
Re: Which winch did we get?
« Reply #1 on: December 29, 2009, 07:15:34 PM »
Looks like an 8000 lbs winch just make some in cab switches for it and see of it works then buy some cable for it
« Reply #2 on: December 29, 2009, 08:30:01 PM »
I'd wager to guess that is a Warn MX 8000 D1.  If it is then it predates the M8000.
You don't really need a controller from Warn which are $$$.  You can either make your own controller and use a generic kit box or you could hardwire it to the dash or console.  For the solenoid box you can get a plastic box that sort of fits and drill holes to screw into the backing plate.  I wouldn't leave them exposed since there is an off chance of you touching them or something arching them as there is no off switch for them.
« Last Edit: December 29, 2009, 08:30:36 PM by Jeffy »
« Reply #3 on: December 29, 2009, 11:07:00 PM »
Warn used to have the solenoid controller diagram on their web page.
You can build one out of std solenoids.
97 TJ - I dont wave
« Reply #4 on: January 04, 2010, 09:05:36 PM »
Your winch appears to be Warn model #25314 Vehicle Winch. This Winch is rated for 8000 lbs.
« Reply #5 on: January 04, 2010, 09:20:13 PM »
That's a Motor PN.
« Reply #6 on: January 04, 2010, 09:43:57 PM »
Looks exactly like my M8000 if that helps...
