Author Topic: Where to get fan control relay.  (Read 4593 times)
Offline dexetr30
  • 4BangerJP.comŪ Donator
  • Aloha Mr. Hand!
« on: January 08, 2010, 07:47:06 AM »
My fan control relay burned up. Anyone have a good online source for relays. Here's a pic of the control module I'm running with the relay I need. The only place I've found so far has a $25.00 minimum order fee and the damn relay is only $2.05. Any help would be appreciated.
Re: Where to get fan control relay.
« Reply #1 on: January 08, 2010, 08:53:23 AM »
ebay is one place, but shipping will be extra - the $3 relay could be the reason it died (unless it's overloaded) but a bosch relay will take you to about $15 or $20 at an autoparts store
this one comes to about $8 shipped http://cgi.ebay.com/40-50-AMP-RELAY-SPDT-SINGLE-POLE-DOUBLE-THROW-NEW-641_W0QQitemZ400041535858QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5d24556972
« Reply #2 on: January 08, 2010, 11:31:32 AM »
Did you burn up the relay and the controller?  I use two separate units.
Here's a site that doesn't seem to have a minimum - http://www.wiringproducts.com/contents/en-us/d36.html
Or you can go to Radio Shack and get this one - http://www.radioshack.com/product/index.jsp?productId=3020762
As long as you're not using the Hi-speed/hi-amp fan, a 40A should be OK.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #3 on: January 08, 2010, 01:28:39 PM »
Thanks to both of you.
Jeff, just the relay burned out. The plastic cover cracked and the relay internals got wet causing it to fry.
« Reply #4 on: January 08, 2010, 03:19:33 PM »
that shouldn't happen (case to crack), there's a 60 amp relay on the site Jeffy posted, i suggest you to go with that one. also, i would monitor the wires to make sure they are not heating up and if they do you'll need an upgrade on the wiring.
« Reply #5 on: January 08, 2010, 04:05:06 PM »
how much was the hole kit? relay / controller / sensor etc?
« Reply #6 on: January 08, 2010, 04:28:36 PM »
not sure about his i got something similar but with the thread in probe for around $40, the thru-fins was about $30 or a bit more - they are available at summit racing among other sellers. The one in the picture is adjustable just like the one i got and in my case was preset to 160 but you can set it to a lower temp even depending on where you locate the probe.
« Reply #7 on: January 08, 2010, 04:31:40 PM »
I paid $26 for the controller, free relay with my fan but they usually cost $3-6.  A couple spools of wire are around $8-10...  I keep wire on-hand though as well.  Misc connector and such too...
« Reply #8 on: January 08, 2010, 06:47:16 PM »
can I get a few links..  to were you can get them
« Reply #9 on: January 08, 2010, 08:37:02 PM »
« Reply #10 on: January 09, 2010, 05:54:50 PM »
were would the thread in one go will it fit in a spot on the stock rad?
« Reply #11 on: January 09, 2010, 06:41:13 PM »
I would ditch the whole controller idea and just use a temp switch and a relay.
Use a screw in temp switch to install near the temp housing or stick the thing in a piece of tube with a weld in bung in the upper radiator works like a charm and it's cheap and reliable
« Reply #12 on: January 09, 2010, 06:44:02 PM »
i welded a 3/8 plate on the bottom of my aluminum rad and had it drilled and tapped for the sender, but in your case i suggest the thru fins or use an adapter that goes on the top hose in which the thread in one goes. Most people use it on top of the rad or the top hose, so I'm not going to suggest the bottom unless you want to experiment (in my case i use a larger radiator so i am hoping with the sender on the bottom the fan will start less since it measures the water temp after it cooled thru the rad).
« Reply #13 on: January 09, 2010, 06:48:57 PM »
it's also basic - with the adjustable one you can tweak better and keep the fan operation at minimum, although like you said it's less complicated with a normal thermocouple and more reliable - i have a 190F basic in parallel with the adjustable switch that will serves as a failover
radark1
« Reply #14 on: January 12, 2010, 04:47:21 PM »
I recently installed the Taurus fan into my 92 YJ......along with the Summitt Racing relay and temp probe. It all worked very well for about two weeks....until I went Jeeping at Pumpkin Eater in So Cal....and I just happened to glance at my temp gauge and it was at the far right side....OH SH**.......overheating. Stopped, opened the hood....and antifreeze was shooting out of the overflow tank. Let it cool off....then unplugged the switch from my driving lights.....wired it right into the battery and the fan.....and off we went. the relay went bad......now it has a fuse inline direct from the fan to the new switch inside the Jeep....and it is then powered off the fuse box as well. So...the relay fried.....and now it is without a relay.....works great.
