Author Topic: warn8274  (Read 12340 times)
Re: warn8274
« Reply #15 on: February 10, 2010, 01:57:35 PM »
Why not keep it simple and carry a spare or two?
Re: warn8274
« Reply #16 on: February 10, 2010, 02:11:24 PM »
I think it would be better to just bring some spares instead of wiring a bunch of solenoids together.  The solenoid box wouldn't be huge otherwise.  Typically you only need one spare anyway as only one usually goes out.  You can wire require the solenoid so you can run on one if you have to.  Having a spare would allow you to keep both forward and reverse functions though.
Re: warn8274
« Reply #17 on: February 10, 2010, 02:15:15 PM »
It takes time to repair things.  Greater reliability means more time for jeeping!
Re: warn8274
« Reply #18 on: February 10, 2010, 02:35:20 PM »
You start making things overcomplicated when you're making backups for the backups though.
drunkencityworker
Re: warn8274
« Reply #19 on: February 10, 2010, 02:59:36 PM »
Pics of new solenoid that replaces 2ones they dont make anymore
drunkencityworker
Re: warn8274
« Reply #21 on: February 10, 2010, 03:03:58 PM »
link to new motor...$78 mine is the keyed kind , newer are 20spline. You have to crack case to tell which you have
http://www.db-starter-alternator.com/Items/Item.aspx?SKU=lpl0015 /  amt0404 - keyway opn fce mtr&caSKU=lpl0015%20/%20%20amt0404%20-%20keyway%20opn%20fce%20mtr&caTitle=NEW%2012V%20%20Winch%20Motor%20for%20WARN%20Keyed%20Shaft%20HEAVY%20DUTY%208274%20LPL0015
drunkencityworker
Re: warn8274
« Reply #22 on: February 10, 2010, 03:05:37 PM »
sorry you might have to cut and paste to get that last one to work...or you may just search on db for 8274 winch motor
Re: warn8274
« Reply #23 on: February 10, 2010, 04:54:05 PM »
Better off with these: (basically 4 of the new style 8274 solenoids)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360136929880&crlp=1_263602_263622&ff4=263602_263622&viewitem=&guid=ae84c12e1230a04378264b46ffec016b&rvr_id=&ua=%3F*I7&itemid=360136929880
That golf cart solonoid is only good for 100 Amps.  The stock setup is 2 solonoids on each side that are rated for 100 amps each.  You are cutting your rating in half with those.  Those would be fine for a small winch but I wouldn't run an 8274 through them for long (unless you use 4)
Re: warn8274
« Reply #24 on: February 10, 2010, 08:23:34 PM »
Thanks for the link, may have to upgrade my motor and keep the old 2.5hp stocker for a spare.
drunkencityworker
Re: warn8274
« Reply #25 on: February 10, 2010, 11:18:36 PM »
Hey oldjep. Those require the new plate they mount to. $170 for that not including the solenoids. Thats what I am trying to avoid. The big $$$
Re: warn8274
« Reply #26 on: February 11, 2010, 06:32:32 AM »
You don't need a new plate, just a drill and some work.
drunkencityworker
Re: warn8274
« Reply #27 on: February 11, 2010, 06:38:54 AM »
And they will still fit under the plastic cover?
Re: warn8274
« Reply #28 on: February 11, 2010, 06:57:29 AM »
Yes.   I'll have to see if I took any pictures when I did mine.  As I recall I had to drill new holes for the solenoids and then take the copper bars and re bend them to fit the front mount configuration.  It's not rocket science, but if you're uncomfortable with that sort of stuff then just get 4 of the old style solenoids from someone other than warn.
Re: warn8274
« Reply #29 on: February 11, 2010, 07:05:01 AM »
Only pic I could find
