Author Topic: Weird revving  (Read 2400 times)
Weird revving
« on: February 01, 2010, 08:47:19 PM »
I got to Panama again, and my Jeep has a new symptom; if I am sitting letting it idle, and (in neutral) I floor the accelarator, it stuters (sp?) a bit and then revs...  It feels like there is too much fuel for the ignition or something, but then it catches on.  This will also happen if I floor it on a gear from low RPMs.  Any idea what this could be?
Re: Weird revving
« Reply #1 on: February 01, 2010, 09:07:07 PM »
maybe FPR/fuel pump, map, tps, o2
i don't think it's ignition since you said you changed (if i remember correctly) pretty much everything after the engine washing incident.
Re: Weird revving
« Reply #2 on: February 01, 2010, 09:49:14 PM »
Why are you going WOT from an idle in neutral?
Sounds normal.  You've dumping a bunch of fuel into the engine before it's able to spin up.  Do that on a carbed engine and you'll usually get the same thing.
Re: Weird revving
« Reply #3 on: February 02, 2010, 12:14:44 AM »
it shouldn't stutter (at least i don't recall having that issue) - first thought FPR, i'm thinking it doesn't reduce the pressure at idle it won't give the extra boost of fuel when suddenly open the throttle, not sure though
Re: Weird revving
« Reply #4 on: February 02, 2010, 01:32:30 PM »
There will be a slight delay and usually a slight drop in RPM before it revs up.
Re: Weird revving
« Reply #5 on: February 02, 2010, 03:17:51 PM »
The I guess it's NOT acting weird...
Re: Weird revving
« Reply #6 on: February 02, 2010, 03:24:19 PM »
I'd gonna guess it's almost like when you're about to stall it and the PCM catches it and revs the engine to 1000 RPM.
Re: Weird revving
« Reply #7 on: March 03, 2010, 08:26:49 AM »
Well, the issue got worse, and all of the sudden, I got a code.  It seems that the TPS plug wiggled itself loose (the safety clip broke some time ago), and this is what was causing the problem.  I actually got scared that the Jeep was breaking down on me, and I would not be able to drive it to Costa Rica, but it was a simple fix (plug the connector back in), so I guess I am still taking the drive...
I think I will use some electrical tape to tape the connector in place and avoid this from happening again.
Re: Weird revving
« Reply #8 on: March 03, 2010, 08:49:55 AM »
use a drop of rtv on the connector plastic part that goes in the tps sensor - that should keep it in place.
Re: Weird revving
« Reply #9 on: March 03, 2010, 03:48:58 PM »
hot glue gun can fix that.. or atlaest that's what they do with computers at some places..
