Author Topic: What type of lift would you put in your jeep?  (Read 9807 times)
0 Members and 14 Guests are viewing this topic.
bammerman
« on: February 02, 2010, 02:32:20 PM »
I have been looking around people's builds and see there are many different lifts and never seen reason's as to why someone chose to go one route or another. If you factor out cost, but be reasonable nothing like 1-2k +, what would you put in your jeep for better ride, clearance, etc...
I am looking at going with a 5.5" Spring Over Conversion Suspension System from Rubicon Express for $309.00 and picking up a CV-type driveshaft and slip yoke eliminator for it.  http://www.xtremeterrain.com/rubiconexpress55springoverconversionsuspensionsystem.aspx
With what I was reading on other sites that said the SOA is a better ride and crawler style lift than a SUA.
(Jeffy made a great post on SOA http://4bangerjp.com/forums/index.php/topic,45.0.html) and here is a small discussion about it. http://4bangerjp.com/forums/index.php/topic,7495.0.html
anyone agree or disagree, wish you did something differently?  I want to go from a 31" tire to a 33" maybe a 35", figured this would be cheaper to do than my 4.88 gear swap at the moment.  (sorry bored at work and I like the discussions here).
« Last Edit: February 02, 2010, 02:43:44 PM by bammerman »
Re: What type of lift would you put in your jeep?
« Reply #1 on: February 02, 2010, 02:45:31 PM »
I'm old school I guess. I like SUA VS. SOA.
I would either buy some RE 4.5XD springs OR have someone like Deaver make me some. Alcan makes nice springs too. They cost more than the off the shelf springs but they are worth it.
« Reply #2 on: February 02, 2010, 02:56:30 PM »
No option for coils?  ???
SOA, ride and flex can't be beat.
....except with coils.  :lol:
« Reply #3 on: February 02, 2010, 03:01:30 PM »
Off the shelf, it's SUA for sure.  it really depends on what you're looking for.  If you're willing to have custom leafs made then that really opens things up without having to go to 1/2 elliptical, multi-link coils or coil overs.
bammerman
« Reply #4 on: February 02, 2010, 03:08:37 PM »
Can the coil conversion really be a "realistic" price 1-2k?  I added them for ya anyways  ;)
« Last Edit: February 02, 2010, 03:10:03 PM by bammerman »
bammerman
« Reply #5 on: February 02, 2010, 03:11:05 PM »
I was looking at SUA's from RE and even if i have to by a SYE and CV shaft the SOA seems cheaper.  maybe I am looking at wrong sites.
« Reply #6 on: February 02, 2010, 03:13:44 PM »
The only way the SOA is cheaper is if you aren't buying new leafs.  ANd your current leafs better be in decent condition.  Otherwise you'll want to buy the 1.5" RE SOA leafs.
bammerman
« Reply #7 on: February 02, 2010, 03:17:55 PM »
Hmm I will have to ask the guy helping me with my SOA.  I only have 70k on the rig, not a good gauge of how good the leafs are though.
« Reply #8 on: February 02, 2010, 03:22:55 PM »
If you wheel it a lot then you can go through springs in a season.  If not then they will probably be fine.  Although you might want switch to all rear leafs still.
« Reply #9 on: February 02, 2010, 03:42:46 PM »
The rear is obviously easier, but even having a shop do the fab work I have less than 1k into the rear of mine parts and labor. Front won't be that cheap though, which is why I am SOA in the front for now.
« Reply #10 on: February 02, 2010, 05:10:48 PM »
For best cost/benefit ratio:  SUA lift kit.  For extreme trails, install some lockers and go three wheeling!
WranglerCOdy
« Reply #11 on: February 02, 2010, 05:29:28 PM »
SOA front/3link Rear.
bammerman
« Reply #12 on: February 02, 2010, 05:42:37 PM »
Have any of you with SOA's ran into problems with the stock nerf bars on the sides?  My guy who is doing my lift and doing a reverse shackle says that the side nerf bars might get into the way.
here is a link to what I am talking about in case I am using wrong term.. The bars under the door. http://farm3.static.flickr.com/2175/2484131815_bca1f168b1.jpg
WranglerCOdy
« Reply #13 on: February 02, 2010, 05:53:57 PM »
take em off and put rock sliders on? and you arent doing the work?
« Reply #14 on: February 02, 2010, 08:09:47 PM »
maybe i missed it (just browsed thru some of the posts) not sure if anyone mentioned it - there's also axle wrap with SOA, so that should also be considered.
