Author Topic: Relay kit for Taurus fan...  (Read 9534 times)
Offline TahoeYJ
« on: February 04, 2010, 02:16:43 PM »
Had nothing better to do today so I went to Pick N Pull and finally got me a Taurus fan   :thumbsup:
I saw the way Jeffy wired it in this thread http://4bangerjp.com/forums/index.php/topic,3781.0.html and was simply going to do this for the time being. I stopped at Kragen to find a 40A relay and came across this kit...
http://kragen.com/ProductDetail.aspx?MfrCode=HAD&MfrPartNumber=3647&PartType=600&PTSet=A
It's only $35 in the store too, and comes with everything I'd need I guess? Seems relatively easy to hook up. If this should work, I'll go pick it up and git 'er done this weekend  :pirate:
« Last Edit: February 04, 2010, 02:17:28 PM by TahoeYJ »
bammerman
Re: Relay kit for Taurus fan...
« Reply #1 on: February 04, 2010, 02:19:06 PM »
So are you close to the NV border?  Know of any good spots to start taking my YJ out to play once I get my lift?
Sine Deviance
« Reply #3 on: February 04, 2010, 10:58:56 PM »
Hmm... this link isn't working for me.
when you get there just type in 3467 in the search part box - it's the hayden automotive thru fins adjustable fan switch.
Offline TahoeYJ
« Reply #4 on: February 05, 2010, 12:27:21 AM »
Bammer- I lived in south lake at the time that I registered here but have since moved back to the bay area. But there's lots of short/fun trails in the area
But will this kit work? It's just a universal kit with w relay, temp probe, thermostat, and fuse/wiring. If it will work I'm going to pick it up tomorrow morning and put it in
« Reply #5 on: February 05, 2010, 12:58:09 AM »
only for the low speed from my understanding (which is what you would use the Taurus fan at anyway). if you want the high speed then you will need to cascade another relay (rated for higher amperage)
Offline TahoeYJ
« Reply #6 on: February 05, 2010, 12:35:34 PM »
That's what my friend was saying, that if I ever wanted to use the high speed I could just run a different relay. And until I upgrade my alternator I won't worry about the high speed.
« Reply #7 on: February 05, 2010, 01:48:19 PM »
i think you'll have to use an external relay (not just replacing the relay into the existing socket) - i bought the same unit just with the thread in instead of the push in probe/sender - the socket and wiring are rated for 40 amps, it's safer to get the command wires off the socket and have an external relay with appropriate wiring rather - that way you don't risk melting the socket or overheating the unit either (not to mention melting the wires).
« Reply #8 on: February 05, 2010, 04:23:10 PM »
Even on low, you'll get a spike and power draw that is noticeable enough to disrupt the idle.
« Last Edit: February 05, 2010, 04:44:31 PM by Jeffy »
« Reply #9 on: February 05, 2010, 04:34:52 PM »
I can run mine on low (override the temp controller) and even in low, it has more than enough power to cool down a 2.5L, so I would not even bother to wire the high side of the fan...
« Reply #10 on: February 05, 2010, 04:44:09 PM »
Yes, they are strong enough to blow leaves, spiders and even small children and pets from under the Jeep.
Offline TahoeYJ
« Reply #11 on: February 10, 2010, 06:18:00 PM »
Finally got around to installing and hooking it up today. I haven't driven past 45 yet but I definitely noticed a difference. Seems to start just a little quicker and seems much smoother when cruising around the backroads. The $35 relay kit from Kragen worked like a charm, I've got it set to come on around 170-175* right now. I've got about an hour drive to do tonight to go hang out with a friend so that will be a great test run for it
  • Poseur Extraordinaire®
« Reply #12 on: February 11, 2010, 05:18:15 PM »
Picked up my Taurus fan from a buddy today...he grabbed a couple of extra when he bought one for his LS1 TJ. $18.
Offline TahoeYJ
« Reply #13 on: February 11, 2010, 09:16:15 PM »
It definitely seemed to make a difference on the drive last night, it seems quieter and runs noticeably smoother at cruising speeds. I think I'll set the thermostat to turn it on around 190 for now, just so it saves my alternator a little work until I upgrade it. But it was definitely worth it and an incredibly easy swap  :thumbsup:
« Reply #14 on: February 12, 2010, 10:03:54 AM »
Why do some other sites say to use a 75 or 80 amp relay??  I want to run out now at lunch and pick up the stuff so I can swap this out this weekend.  I would like to add an on/off switch in the cab as well so I can shut it off for water crossings.
