Author Topic: Intake for an XJ  (Read 3410 times)
ChuckC806
Intake for an XJ
« on: February 18, 2010, 09:34:27 PM »
Anyone know if there's anyone that makes an intake for an 4banger '99 XJ?  I've seen some for the 4.0l and some for the 2.5l wranglers, but not for the XJ.  Will the one for the 4.0l fit the 2.5l also?  Or am I better off going custom?
Re: Intake for an XJ
« Reply #1 on: February 18, 2010, 09:38:40 PM »
Safari Snorkel is the one thing I've seen.  Problem with the XJ is that it's stuffed pretty tight so a CIA isn't really going to work well.
ChuckC806
« Reply #2 on: February 19, 2010, 06:05:27 PM »
been thinking about doing something similar to the cowl intake system that i saw posted on here somewhere, but instead, place a mini-scoop on the hood, and then the rest would be similar.
ChuckC806
« Reply #3 on: February 21, 2010, 07:44:35 AM »
Since we're talking about the air intake.  Can anyone tell me what the hell that little "black box" is attached to the intake tube and sits right above the throttle body?  Been searching all over and can't find out what it is.
« Reply #4 on: February 21, 2010, 01:52:17 PM »
I don't have any pictures but I'm going to guess it's an expansion chamber to help slow the air speed down.  Supposedly, it's to quiet any noise like whistles and the vacuum sound.
« Reply #5 on: February 21, 2010, 03:22:14 PM »
It quiets the intake down and allows the air pulses to smooth out..
The Honda S2000 has one of these thats highly developed and it
accounts for a serious amount of the engines horsepower for an intake system...
ChuckC806
« Reply #6 on: February 21, 2010, 06:53:57 PM »
here's a pic of it.  if i were to put an intake in, is it necessary?
dave, when you say it accounts for a serious amount of the engines horsepowere, is that a good thing or bad?
« Reply #7 on: February 21, 2010, 07:18:38 PM »
i would cut that cancerous tumor off the intake (lol). i doubt jeep took the time to design it to add hp like the honda one that someone spoke of earlier.. (but i could be worng)
« Last Edit: February 21, 2010, 07:19:12 PM by chardrc »
« Reply #8 on: February 21, 2010, 09:04:46 PM »
Is the rear fresh air vent connected to the box?  I don't see any lines going forward from behind the box.
« Reply #9 on: February 22, 2010, 12:09:15 AM »
On a S2000 its very very good... On a Jeep? who knows...LOL
ChuckC806
« Reply #10 on: February 22, 2010, 05:17:54 PM »
nope, there's nothing connected to it.  it feeds into the "box" on the top and then underneath, it feeds right back into the intake tube just above the throttle body.  that's why i can't figure out what the hell it's there for
« Reply #11 on: February 22, 2010, 06:19:29 PM »
I'm betting it's for sound rather then any perfromance.  You could swap the elbow for a standard one but then you would need to run the vent line to the airbox.
ChuckC806
« Reply #12 on: February 22, 2010, 06:58:29 PM »
If I'm correct, the vent is just below the driver's side windshield wiper on the cowl.  Or at least that's what I'm led to believe because it's got holes on that side of the cowl, but it's just the opposite on the passage side cowl.
However, from what you're saying, assuming you're correct, I could add an intake tube, and then run an "excess" vent line from the tube near the throttle body back to the air box and it would basically do the same job.  Right?
95yjman
« Reply #13 on: February 22, 2010, 07:32:37 PM »
I run this on my cherokee, ya its on a 4.0 Liter but I have the exact same one on the 2.5L in the YJ
ChuckC806
« Reply #14 on: February 27, 2010, 02:50:18 PM »
after pulling the intake apart, the intake tube doesn't even feed into it at the top, it's capped off.  so i'm thinking it's just to hold air, like an expansion chamber, maybe?!
