Author Topic: fan ford  (Read 4665 times)
  • Poseur ExtraordinaireŽ
Re: fan ford
« Reply #15 on: March 12, 2010, 08:50:09 AM »
2-speed one.
Re: fan ford
« Reply #16 on: March 12, 2010, 09:02:56 AM »
The other ones are $50 more!!
The 2-speed one should work great, right??  What would be the advantage of the more expensive ones??  Start-up??   :confused:
Re: fan ford
« Reply #17 on: March 12, 2010, 07:49:43 PM »
Less draw on start-up and it only spins the fan as fast as needed to stay cool, so no wasted draw ever.
Re: fan ford
« Reply #18 on: March 12, 2010, 08:32:36 PM »
I'm probably going to go with a computer controlled unit as the shutter from having the fan kick in and the alternator spool caused vibrations which caused the monolith inside the cat to break apart.   :brick:
Re: fan ford
« Reply #19 on: March 12, 2010, 09:32:35 PM »
I'm on CAT #5 in 200 K miles, are you sure that's what did it?  :biggrin:
I like the muti speed idea as well , just for quiet and effiency sake....
Re: fan ford
« Reply #20 on: March 12, 2010, 10:23:15 PM »
Yes, it was the fan/alternator.  It really shakes when it turns on and it beats on the exhaust.  I had no problem when I was running the fan 24/7.  My Jeep doesn't eat cats.  I'm on #3 as I thought #2 was bad but it turned out to be the muffler.
Re: fan ford
« Reply #21 on: March 12, 2010, 11:15:57 PM »
I have noticed that if the tail pipe can rattle against anything it seems to trash the cat in a hurry.
My random tech cat has outlasted the other stock style ones by a lot so far....
Re: fan ford
« Reply #22 on: March 13, 2010, 11:07:40 AM »
Yeah, which is a problem since there is a dampener at the front of the cat.  When I replace the cat in the summer I'll probably order a DCC box as well.  I would probably get around it by removing the dampener but then I might run into another problem.  So a variable controller is probably the better way to go.
Re: fan ford
« Reply #23 on: March 13, 2010, 10:39:20 PM »
Order now if you want the DCC controller by summer ;)
Well worth the wait, but I hope he's updated the lead time on his website.
