Author Topic: spark plug gap  (Read 1645 times)
mikeymuy
spark plug gap
« on: February 28, 2010, 10:30:04 AM »
Hey guys I went wit the msd coil and wires after all so I like it... Now question what plugs should I run and what should I gap them at??? Thinkin autolites or champions thanks
Sine Deviance
Re: spark plug gap
« Reply #1 on: February 28, 2010, 11:08:30 AM »
NGK V-Power FR6-1's are my recommendation for the plugs. Those are good plugs, they only cost $2.50 a plug, and they are one step colder than OEM, which will help you since you're running upgraded ignition.
I think the OE gap is 0.35" for us. With the MSD kit you should be able to safely go as big as 0.60" and possibly even 0.65" without issues. The MSD kit should actually have a recommendation for that in the manual or somewhere.
« Last Edit: February 28, 2010, 11:16:12 AM by Sine Deviance »
mikeymuy
Re: spark plug gap
« Reply #2 on: February 28, 2010, 11:20:47 AM »
Iam running only the coil and wires no box
Sine Deviance
Re: spark plug gap
« Reply #3 on: February 28, 2010, 09:18:07 PM »
You shouldn't need a box. The coil should bump voltage up enough for 0.60" or 0.65" plug gap.
Re: spark plug gap
« Reply #4 on: March 01, 2010, 08:08:45 PM »
The only way to gap larger is by trial and error.  .035" is stock, so try .045" and go up .005"-.010" increments.  Then if it misfires, back it down.
