Author Topic: Ford 8.8  (Read 3943 times)
BlackYJ
Ford 8.8
« on: January 17, 2006, 06:09:56 PM »
I have been looking into doing a Ford 8.8 swap but one thing I am still confused about is where my driveshaft will have to be shortened.  I have searched and seen a couple saying yes and others saying no.  Can anyone here help me out.
Ford 8.8
« Reply #1 on: January 17, 2006, 06:18:41 PM »
It will depend on several factors.  Suspension lift, engine lift or tcase drop, location of the housing and what not.  Remember that the I6 AX15 drivetrain is the longest and the I4 AX5 is the shortest.  I believe the difference is close to 4" in the rear driveshaft length.
The pinion location will be higher and closer to the transfer case then with the D35c. But may work out fine with your current driveshaft.  What you're going to have to do it bolt up the axle and check it.
Oh and you can also adjust your axle location with adjustable perches.  Perches will usually have three holes instead of the one.  This allows the axle to be moved an inch in either direction.  You shouldn't have any problems from moving it since it's minimal.
low output 2.5
Ford 8.8
« Reply #2 on: January 17, 2006, 10:32:55 PM »
my d/s was fine it compressed it about a half inch on the slip but....................................................... i had enough room with my set up but should be fine with most others
BlackYJ
Ford 8.8
« Reply #3 on: January 18, 2006, 08:23:54 AM »
I am currently running about 3-3.5" of suspension lift with a 1" t-case drop, but it sounds like from you guys are saying it should be okay.
Thanks
Ford 8.8
« Reply #4 on: January 18, 2006, 12:11:37 PM »
Well, it's hard to say without just trying it and seeing it it will work.
low output 2.5
Ford 8.8
« Reply #5 on: January 18, 2006, 12:25:03 PM »
we did my buddies 8.8  last night its got  4 inch skyjacker lift big o shackles and a 1 inch t case drop stock length shaft no fancy stuff it went right in has more slip in the t case and no vibes just make sure both ( rear and t case) yokes are are on the same angle
