Author Topic: Zipper lube?  (Read 5611 times)
Offline smashcoast
Zipper lube?
« on: March 14, 2010, 09:05:31 PM »
What method or stuff do you guy's use to lube your soft top zippers for easy operation?
Dylan
Re: Zipper lube?
« Reply #1 on: March 14, 2010, 10:21:04 PM »
I use a spray can of silicone lube.
Re: Zipper lube?
« Reply #2 on: March 15, 2010, 06:58:39 AM »
Rub a bar of soap across the open zipper, then close and open several times. I do this every early spring and late fall.
GBJeep
Re: Zipper lube?
« Reply #3 on: March 17, 2010, 01:58:10 PM »
Chapstick also works for your zippers.  Not sure where I heard that, but I have been using it for 2 years and have not had any problems.  It is not messy and easy to apply.
Re: Zipper lube?
« Reply #4 on: March 17, 2010, 04:12:06 PM »
Basically just wax.
Dylan
Re: Zipper lube?
« Reply #5 on: March 19, 2010, 10:46:05 PM »
Basically just wax.
But you can get it in cherry flavour  :dance:
blacknblue
Re: Zipper lube?
« Reply #6 on: March 25, 2010, 11:27:05 AM »
Mopar makes a product for lubricating your zippers.  It has a brush on the end that gets the liquid into the zipper real good.  I saved the bottle and plan on re-filling with a cheaper lubricant like silicone spray or something.  I also keep a caribiner on my key chain that fits the zipper hole to help pull the zipper when I put my top on and off.
bammerman
Re: Zipper lube?
« Reply #7 on: March 25, 2010, 11:58:35 AM »
That isn't a bad idea!
blacknblue
Re: Zipper lube?
« Reply #8 on: March 27, 2010, 09:14:17 AM »
Use graphite lubricant instead of silicone.  Graphite prevents contamination from dirt, water, oil or acids.  Silicone works good on rubber, plastic, vinyl, and nylon.  I remember my mom fixing my stuck zipper on my jacket by rubbing some pencil lead on them,  that might work in a pinch.
Re: Zipper lube?
« Reply #9 on: March 27, 2010, 10:03:43 AM »
I do the same thing. No need to buy anything special or make another trip to the store. Just grab a bar of whatever from the house. Works like a champ.
YJmechanic
Re: Zipper lube?
« Reply #10 on: March 30, 2010, 12:00:46 AM »
i guess i dont mess with my windows too much,  i never really worried about it,  sex wax would probably work well cause it last awhile and resists water pretty well
btw its for surfing not what u were thinking :flush:
