Author Topic: Got her fire up today. :) But gettin some codes  (Read 2755 times)
Complete Loser
« on: March 25, 2010, 10:43:31 AM »
Well, i put on a pacesetter header, a tb spacer, and a 4.0 throttle body. Along with a 130a alt. She runs, but doesnt start or run as good as i would have hoped.
The idle is very smooth and at about 900rpm.
I bought a new TPS for my 2.5 tb and went ahead and put it in this 4.0 tb. Now i am getting a tps code (24). Just wondering if i need to go back to the original 4.0 tb sensor?
The other codes are
12 and 33
Re: Got her fire up today. :) But gettin some codes
« Reply #1 on: March 25, 2010, 11:51:06 AM »
The other codes are
12 and 33
i would take the tps back and get another one
swap the IAC valve and housing as well
Complete Loser
« Reply #2 on: March 25, 2010, 09:41:26 PM »
I was going to swap the IAC. I pulled them both off, and they both looked a good bit different internally. The 'plunger' part of them looked bigger on the 4.0. ?  So i left them on their respective throttle bodies.
« Reply #3 on: March 25, 2010, 10:18:22 PM »
you need the 2.5L IAC valve and housing on the 4.0 t/b - the 4.0 require a lot more air at idle than the 2.5 that's why they are different.
Complete Loser
« Reply #4 on: March 25, 2010, 10:21:10 PM »
Im such a gomer. I didnt even notice that the housing was removable. Thanks.... yet.... again.
I feel like i should be paying you guys.   How bout a round of beers?  :beer:
Complete Loser
« Reply #5 on: March 26, 2010, 10:03:46 AM »
Awesome! Those require the torx bits with the hole in the middle!  :clap: Now this is turning out like a normal vehicle project.  :weee: Off to get some bits. lol
« Reply #6 on: March 26, 2010, 02:43:35 PM »
if you're ever in Vancouver i'll take you up on that
not sure if it will fix your tps code though, but i would at least reset the computer.
« Reply #7 on: March 26, 2010, 08:05:36 PM »
there called tamper prof torx
Complete Loser
« Reply #8 on: March 26, 2010, 10:10:27 PM »
yup. just bought some of the torx bits. They sure are proud of them. $23 for about 7 bits.
How do i reset the codes on the computer.
« Reply #9 on: March 26, 2010, 10:13:55 PM »
remove the ground from battery, touch it to the + and leave it off for 5 minutes.
