Author Topic: Rear sway bar  (Read 1776 times)
pajeep
Rear sway bar
« on: March 29, 2010, 04:18:42 PM »
 I have a 97 TJ, Im curious to know if i can completly disconnect my rear sway bar? Whats the PROS and CONS.
Re: Rear sway bar
« Reply #1 on: March 29, 2010, 06:16:08 PM »
From what I understand, you won't gain much flex by removing it.
Re: Rear sway bar
« Reply #2 on: March 30, 2010, 12:17:32 AM »
The cons are very poor handling, onroad and off.  Don't do it, not with coil springs.
melbill
Re: Rear sway bar
« Reply #3 on: April 03, 2010, 05:49:03 PM »
The way I understand it with the coil springs sway bars are a must.  You can get very dangerous extreme body roll without them.
Offline aw12345
    • my jeep picture page
Re: Rear sway bar
« Reply #4 on: April 03, 2010, 07:19:05 PM »
It's not the end of the world to run without the rear sway bar the newer SE TJ's don't have one. However there is no real benefit in removing or disconnecting it either, the rear flexes fine with it hooked up and it does help to keep it from leaning over on of camber sections, also help eliminate a bit of body roll on the street and it helps keep the rear springs in place offroad.
See plenty of flex with the rear swaybar hooked up and the front anti rock swaybar hooked up also
2006 Jeep Wrangler TJ SE
2004 Jeep Wrangler TJ SE
Re: Rear sway bar
« Reply #5 on: April 04, 2010, 09:41:49 AM »
Nice pic, makes me want to go out right now.  :beers:
