Author Topic: Need a new radiator soon  (Read 6501 times)
Re: Need a new radiator soon
« Reply #15 on: April 03, 2010, 07:39:30 PM »
for a stock like is $70 which i think is freakin' cheap - they quoted me $220 here at the parts store before i looked on ebay (and good thing i did). comparatively a rad for my camaro was $115 at the same store, have no idea why the difference as the camaro one is bigger, might be the mounting brackets that come with the rad.
« Reply #16 on: April 03, 2010, 11:15:36 PM »
most aftermarket radiators are built for all automatic transmissions. they would have a plug for the transmission cooling lines. though i personally would rather bypass it with a large add on cooler
It's good for those who do not have Auto's to get the coolers in case they want to run a cooler for something else, like PS or oil.
For those with an auto, I would still use a radiator cooler WITH an external cooler.  You can't really have too much cooling.
« Reply #17 on: April 04, 2010, 04:35:20 PM »
« Reply #18 on: April 04, 2010, 04:41:24 PM »
Here is one with two cores just a bit more expensive:
http://cgi.ebay.com/ebaymotors/1995-95-JEEP-WRANGLER-YJ-2-5-4-0-New-Radiator-2-row_W0QQitemZ180489409795QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2a0601d503
Would this cool significantly better than the 1-core?
EDIT: it has plastic tanks judging by the picture
that is still 1'' thick so not likely, this one is 1-3/4'' thick so it's better http://cgi.ebay.com/ebaymotors/97-98-99-00-01-JEEP-WRANGLER-YJ-ALL-ALUMINUM-RADIATOR_W0QQitemZ250511631234QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3a53a82382#ht_4209wt_939
and is the same price. might want to send him an email to doublecheck it works for '95.
« Last Edit: April 04, 2010, 04:42:54 PM by sharpxmen »
« Reply #19 on: April 05, 2010, 07:59:58 AM »
Good find!  Thanks.  It is ambiguious with the 97 YJ, better to check as you said.
« Reply #20 on: April 05, 2010, 09:08:34 AM »
do an extensive search on ebay - there are tons of them on there. I found mine that way, same as the link i posted (2core, 1-1/4'') but it was listed for 91-95 YJ and was only $125 shipped. i spent a good hour looking thru all the listings.
« Reply #21 on: April 05, 2010, 10:49:14 AM »
Both Autozone and Advance Auto Parts list the same part number for a 1995 YJ and 1997 TJ radiator for the 2.5 engine.  It looks like there should be no problem.
Thanks
« Reply #22 on: April 05, 2010, 11:19:28 AM »
Now you got me intrigued; so how do you go about using it as an oil cooler?  Do you need to tap the oil pan?  The PS sounds easier...
I bought mine for about $130 and it does have the auto cooler, but since I am not using it, it would be an interesting project to do now that the Jeep is in Costa Rica and I can work on it (until June, anyway!).  I would prefer to do the oil, but if it's too complicated, I may do the PS.
By the way, on the original subject, I bought mine off eBay, but I think the place I got it from was Radiator Barn or something like that...  AL with welded tanks.  I think it was a single row one, but I dont remember (cant see it on the pics, and I am in Panama until Wednesday while the Jeep is in Costa Rica)...  Here's a Pic of it.
« Reply #23 on: April 05, 2010, 11:46:00 AM »
you put an adapter on the oil filter (it is sandwiched between the oil filter and the oil filter mount), it would have 2 fittings coming out of it, 1 feed and 1 return. One problem though is that you want a thermostat on it, those are more expensive - otherwise in the winter you would keep the oil too cold which is not desired. if you do want to do it i suggest using a separate oil rad instead and still use an adapter with a thermostat built in.
EDIT: something like this http://cgi.ebay.com/ebaymotors/CHEVY-OIL-COOLER-ADAPTER-TRANS-DAPT-BRAND-NEW-N-R_W0QQcmdZViewItemQQhashZitem23065ec0a2QQitemZ150430728354QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
this one has a thermostat and it is the way to do it, i don't recommend using the cooler without one unless you are in a hot climate http://cgi.ebay.com/ebaymotors/GReddy-Oil-Cooler-Adapter-with-Thermostat-M20XP1-5_W0QQcmdZViewItemQQhashZitem53e08d4e4eQQitemZ360249642574QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
or this one http://cgi.ebay.com/ebaymotors/Chevy-V8-PH3506-13-16-Thermostat-Oil-Cooler-Adapter-Kit_W0QQcmdZViewItemQQhashZitem56333d8073QQitemZ370226856051QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
not sure if any of them would work on the Jeep though, i listed these just as an example
« Last Edit: April 05, 2010, 12:11:56 PM by sharpxmen »
« Reply #24 on: April 05, 2010, 06:20:47 PM »
Winter in Panama you are talking about 85*; Costa Rica is cooler, and can go down to 65*, but still, not cold...  But I'll see if I can find one for the Jeep; for 30 bucks, it's not a bad idea.  Besides, it should give me one more quart of capacity, which is not bad.
« Reply #25 on: April 05, 2010, 06:28:00 PM »
go with the thermostat one - in the last link i posted they say if you give them the oil filter p/n they'll tell you if it works on Jeep. It was $20 more but the thermostat is worth the difference (would take lot longer for the oil to come up to temp otherwise).
« Reply #26 on: April 07, 2010, 11:44:19 AM »
I just ordered the 1 3/4" thick 2 row core.  Is this like the one you got?  Did you have to trim the shroud due to the extra thickness?
Thanks
« Reply #27 on: April 07, 2010, 12:08:26 PM »
Thanks
yeah, that's the one. The tanks are the same thickness, you don't have to trim anything - the outside dimensions are same as stock, if you look at yours on the engine bay side you'll see that the core only uses 1/2 the tank basically whereas this one would have the core over the whole width almost.
« Reply #28 on: April 07, 2010, 12:27:58 PM »
I just got a sandwich type one with thermostat...  I'll hook it up later on.  This with the eFan and DCC controller should keep the engine nice and cool when wheeling on a hot Panamanian day (over 100*).
« Reply #29 on: April 07, 2010, 01:15:49 PM »
Great! Sounds like it will be just bolt on.  Thanks
