Author Topic: Jet AFR monitor  (Read 2065 times)
Jet AFR monitor
« on: April 08, 2010, 02:33:26 PM »
Anybody have any experience with this: http://www.jegs.com/i/JET/561/66110/10002/-1?parentProductId=1154459
Wondering how well it works as it runs off the OEM o2 sensor, not an aftermarket wide-band sensor.  Price is right too.
Re: Jet AFR monitor
« Reply #1 on: April 08, 2010, 02:52:18 PM »
I've been curious about it as well.
Re: Jet AFR monitor
« Reply #2 on: April 08, 2010, 04:40:22 PM »
This one is cheaper and seems to be independent from the stock unit (although, it seems like a narrow band as well).  I also trust Edelbrock more than Jet, but that's because I dont know Jet and I have heard a lot about Edelbrock...  Could be due to me not knowing the brand (I guess Jet could also be a well established brand, but I dont know).
Re: Jet AFR monitor
« Reply #3 on: April 08, 2010, 05:07:48 PM »
so it will tell you if you're in closed loop, open loop, if the O2 sensor is faulty, if you're above or below 14.7 AFR - you will not know if it's 13.5 or 11.5 AFR for example, the output of the O2 is the same in that case, same goes for lean but in that case it's easier.
Instead of this i would rather purchase an led based one as the response time is faster and the information is the same (there's really no point of having numbers displayed, you would know right away when the PCM is in closed loop and when in open loop using the led based ones, there's really no information past that point as the O2 sensor is not providing anything more that in the close range of 14.7)
at $187 i'm sorry but the price is stupid - for $12 more you can get an innovate LC1 with a wideband O2 (included) and computer logging capabilities and software or get the edelbrock wideband o2 meter for (i think) something like $130 (that also comes with a sensor).
this is from the Jet manual for this (read page 3 and 4 in this doc for examples of almost useless information to be displayed http://www.jetchip.com/DownloadFile.asp?File=pdf/howto/Air%20Fuel%20Monitor/Air_Fuel_Monitor.pdf)
Quote
Reading the Air/Fuel Meter:
The Oxygen Sensor must be at operating temperature before you will get any reading
on the screen, normally it must reach 600 degrees F before you will get an accurate reading.
Once up to operating temperature at idle and cruise the air/fuel ratio will cycle up and down,
this is normal, it is the vehicles PCM trying to maintain a perfect air/fuel ratio. This ratio is
called stoichiometric, at this ratio all of the fuel and oxygen is burned. During acceleration
you will notice that the meter will move to a richer mixture, this is also normal, by accelerating
you have increased the amount of fuel the sensor is reading.
EDIT:
that's edelbrock one i was talking about and it is wideband.
« Last Edit: April 08, 2010, 05:09:10 PM by sharpxmen »
Re: Jet AFR monitor
« Reply #4 on: April 08, 2010, 05:31:25 PM »
Then it is not bad at all; it's fugly, but it works...
Re: Jet AFR monitor
« Reply #5 on: April 08, 2010, 05:45:34 PM »
it's a fair unit for the price if you don't need session logging (in most cases you don't)
Re: Jet AFR monitor
« Reply #6 on: April 08, 2010, 06:07:32 PM »
Would be cool to be able to log the data though.
Re: Jet AFR monitor
« Reply #7 on: April 08, 2010, 07:58:32 PM »
yeah, but the only thing with the innovate one is that it won't log rpm unless you get an additional device - in my case it was worth getting the SSI-4 as i want to log AFR, boost (with a 2 bar MAP Sensor), tps, rpm, and another parameter (planning to do the IAT but have not decided yet).  Not sure if the PLM devices one has the ability to log rpm, innovate used to have an rpm converter available for that (read that somewhere) but i'm not sure if it was working with LC-1 or if it was part of the LM-1 package
