Author Topic: Took her for a drive today. :) ........... :(  (Read 1446 times)
Complete Loser
« on: April 11, 2010, 01:01:05 PM »
She works pretty good. But when i got back home, i noticed the port on top of the valve cover was puking a good deal of oil (and oil smoke i guess aswell).
I used to have a commanche with the sixer in it, and it did basically the same thing (just not as bad). It would always ruin the air filter, so i removed the hose from the breather. Now ive dont the same to the jeep.
So this symptom looks familiar to me, but pukes a bit more than i like.
Any thoughts?
Re: Took her for a drive today. :) ........... :(
« Reply #1 on: April 11, 2010, 01:17:10 PM »
Clean your CCV fitting.  It's the small brass fitting that screws into the valve cover at #1 cylinder on the driver side.  If that gets clogged, oil will get forced out the fresh air vent.  See if that fixes it.
Complete Loser
« Reply #2 on: April 11, 2010, 01:46:21 PM »
you sir (or mam), ARE GOOD! lol That fitting was plum full o junk. Couldnt even get a piece of wire through it. So stuck it on the drill press and drilled it out.  :naughty:
Now in this vid. Ive fixed that fitting. And plugged everything back in. Its now MUCH better.  :doggy:
But a question. I pulled the oil fill cap off, and could feel a decent amount of pressure coming out. Just curious if thats normal. Heres the vid.
« Reply #3 on: April 11, 2010, 02:59:22 PM »
Yes, you'll get some crank case pressure from the pistons moving up and down.  That's normal.  It's supposed to force the gases into the intake through the CCV.
Complete Loser
« Reply #4 on: April 11, 2010, 04:11:13 PM »
Kewl.  :beers:
YoungJeeper
« Reply #5 on: April 16, 2010, 01:30:49 AM »
 Yes!
I had some oiling of the air filter as well...
Thanks Jeffy!
