Author Topic: running wire  (Read 1693 times)
enginethatcould
running wire
« on: April 25, 2010, 03:48:08 PM »
Where are you guys running wires through the firewall? I need to snake a couple of things from the engine bay into thebut want to cab. I was going to drill a hole and use a grommet, but wanted to see if there is a spot I could squeeze it through.
TIA
Re: running wire
« Reply #1 on: April 25, 2010, 03:56:34 PM »
on my 1990 there is a unused hole with rubber plug above where all the wires go through the firewall to get to the under dash fuse box thing on the drivers side. i made a hole in the rubber plug and ran wires through there for a few things.. not shure if that extra hole exists on the mpfi  jeeps.
Re: running wire
« Reply #2 on: April 25, 2010, 03:57:37 PM »
On a YJ, I drilled a hole thought the big grommet in the firewall above the throttle.
Re: running wire
« Reply #3 on: April 25, 2010, 04:32:14 PM »
I drill a big hole in the fire wall and use glad hand transport air connector seals I got from my dad's shop.
found this pic 6601 are the ones I use they work great!!
Re: running wire
« Reply #4 on: April 25, 2010, 04:35:55 PM »
or you can run them thru the existing grommets located somewhere around the brake booster - if it's a wire or 2, otherwise better to use a new hole and grommet like they^ said
