Author Topic: Intake Turbo charger  (Read 3083 times)
Re: Intake Turbo charger
« Reply #1 on: April 26, 2010, 02:33:50 PM »
http://cgi.ebay.com/ebaymotors/Jeep-Wrangler-Intake-Supercharger-Turbo-Performance-_W0QQcmdZViewItemQQhashZitem27ac7cf7ceQQitemZ170397595598QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Anybody try this or know anything about it?
yeah, it will give you an extra 50HP and about 75ftlb of torque....  :nono:
i am obviously sarcastic, save your time and money - if you want information on forced induction there are a lot of posts here related to that.
just as a note, forced induction is increasing the amount of air that the engine inhales per cycle and you can then burn more fuel to produce more power - similar to increasing the displacement of the engine but with a tradeoff since any turbo or supercharger will consume some energy as well
EDIT: the device you listed is not a turbo or supercharger, same goes for the electric turbos on ebay - just a way to make easy money with false claims and placebo effect.
« Last Edit: April 26, 2010, 02:36:12 PM by sharpxmen »
Sine Deviance
« Reply #2 on: April 26, 2010, 03:32:56 PM »
What sharpxmen said. It's useless. In fact it will probably make your lose power, because all it does is add a huge restriction to your intake piping.
warro
« Reply #3 on: April 26, 2010, 09:10:52 PM »
sounded to good to be true. thanks for the imput
« Reply #4 on: April 26, 2010, 09:19:50 PM »
before you go turbo you can make some other mods to increase power (enlarged throttle body as in 4.0L or even better a 62/63/64 mm, more fuel by increasing fuel pressure, high flow air filter, electric fan, exhaust header and high performance cat and muffler) - all these would give you 15HP or so if not a bit more depending on what you use. You can also try a t/b spacer as it's been known to provide some increase as well.
« Reply #5 on: April 27, 2010, 07:52:39 AM »
MAHAHAHAHA I have seen a few of these things come in to the shop here causing eng lights and problems.  seen a guy wire in some resistor and void warranty on a intake air temp sensor to. and he made a real mess doing the wiring him self!! but anyway ya save your money
« Last Edit: April 27, 2010, 07:55:23 AM by Torch_Ind »
TrailsLessTaken
« Reply #6 on: April 27, 2010, 01:30:42 PM »
That reminds me of this picture somebody put up a while ago:   :lol:
Offline TahoeYJ
« Reply #7 on: April 28, 2010, 12:00:36 AM »
My dad bought one of those electric superchargers for his gasser after he sold his Duramax in September... I had no comment for him. He claimed it put out a whopping 2.5 lb
boost and thought it was something to brag about... Until I told him his duramax put out 20-25+ stock.
The stupid thing only works at full throttle. And it does virtually nothing then too. Huuuuuge waste of cash
