Author Topic: Power steering cooler  (Read 1849 times)
« on: April 26, 2010, 05:39:36 PM »
I´m considering using the tranny cooler in the new radiator to cool the power steering fluid.  Should the cooler be placed a) between the steering box and the reservoir or b) between the reservoir and the pump?
It seems a) would be better so it would be downhill from the reservoir to the pump and not uphill from the cooler to the pump... but not sure.
Thanks
Re: Power steering cooler
« Reply #1 on: April 26, 2010, 06:17:32 PM »
I would put it between the steering box and the reservoir as the fluid will be at it's hottest.
« Reply #2 on: April 26, 2010, 07:33:31 PM »
Between the steering box and the reservoir.  I picked up a cheap Hayden tranny cooler from the parts store for about $25, works good for power steering.  It's a MUST if you run a front locker.
« Reply #3 on: April 26, 2010, 07:49:16 PM »
This has been on my list of to do's for years. I picked up my cooler from Summit. It's a 4 pass type cooler. I debated to go with the heat sink type but choose the multi pass. Now I just need to get off my butt and do it.
« Reply #4 on: April 27, 2010, 08:02:17 AM »
Thanks to all who replied.
