Author Topic: MALLORY CDI Ignition  (Read 3371 times)
binerypir8
« on: January 23, 2006, 02:04:34 PM »
has anybody had any luck installing the Mallory Hyfire 685VI Ignition Controller?  I cant figure out how its supposed to be hooked up on my 95 YJ and all the schematics are for every other vehicle but the jeeps.... Anyone??
« Reply #1 on: January 23, 2006, 02:49:32 PM »
Can you scan or take a pict of the schematic?
binerypir8
« Reply #2 on: January 24, 2006, 12:35:14 PM »
Heres the link to the directions from Mr. Gasket's Website
http://go.mrgasket.com/pdf/685_6851.pdf
I've looked around for a while i cant find anybody else thats installed one of these on a yj
Thanx
« Reply #3 on: January 24, 2006, 01:23:46 PM »
Wow, that thing wants to splice into everything.  :shock: You're going to have to make Y connectors for the MAP.  I suspect that it's most similar to the MOPAR setup.
I looks like it's designed to be a stand alone system which is ok but your PCM wants to know what everything is doing also.  So you'll need to have both hooked up.  I suspect this is one of the main reasons no one runs one on a newer Jeep.
