Author Topic: Rear axle end play?.... question  (Read 4320 times)
Complete Loser
« on: May 19, 2010, 11:05:08 AM »
Well, when i had my rear jacked up and installing tires, i noticed i could pull the drivers rear axle out farther than seemed normal. The pass rear axle pulls out about a 1/4" or a tad less. That seemed normal to me. But the drivers rear pulls out like 3/4" or so.
Is that acceptable?
If not, what is the problemo and remedy?
Ive had the diff cover off when changing all fluids. Nothing broken or jumping out at me.
Re: Rear axle end play?.... question
« Reply #1 on: May 19, 2010, 11:21:09 AM »
Is this a d35 or something else?
« Reply #2 on: May 20, 2010, 06:06:35 AM »
3/4" of play is excessive
« Reply #3 on: May 20, 2010, 03:29:20 PM »
Yeah, something's up with 3/4"  There should be about 1/4" of play with the center pin in.
« Reply #4 on: May 20, 2010, 03:42:08 PM »
bearing carrier, but then should have the same problem on both sides - i can't see the center pin being worn out that much and the c-clip is about 1/4'' thick so that's not it either - i guess taking the diff cover off would give the answers to this. the end of the axle is about 1/4 '' as well (between the c-clip groove and the end) so that's another negative - combine the c-clip and axle end and you still get a max of 1/2'' at which point the axle would actually come out. the only other thing i can think of is a cracked carrier but i would think there would be some nasty noise coming out of it when rolling so unlikely).
Complete Loser
« Reply #5 on: May 27, 2010, 08:55:47 AM »
Thanks for the replys. (im still not getting notifications. :(    )
I will check it out.
Its the stock rear axle. So i think its a d35.
« Reply #6 on: May 27, 2010, 09:12:19 AM »
click on Profile and then go to Notifications and Email in the left hand menu - check the appropriate boxes in that page
Complete Loser
« Reply #7 on: May 27, 2010, 10:17:27 PM »
Ok. Imuh dumbass.
I took the tire off to have a good look at the actual axle movement. Its exactly 1/8".
The pass side is exactly half that. So all i can assume is late hours and too much guiness (and my buddy saying thats waaaay too much axle movement) caused me to over guesstimate the play.
 :crap:
lol
Complete Loser
« Reply #8 on: May 27, 2010, 10:20:05 PM »
ive done that several times. All 3 boxes are checked.
« Reply #9 on: May 27, 2010, 10:29:37 PM »
Profile-
Personal message options -
Check the box that says show pop up for PM's   :wave:
« Reply #10 on: May 27, 2010, 11:29:27 PM »
Profile-
he means he's not getting emails when someone posts in his threads
maybe in your junkmail folder
« Reply #11 on: May 28, 2010, 09:38:58 AM »
Gotcha  :brick:
« Reply #12 on: May 28, 2010, 09:49:25 AM »
Google started throwing mine in the SPAM folder about 2 weeks ago.  I cleared them by selecting all and clicking Not Spam.  Now they're all good here.
At first, I thought I wasn't getting any because the GMail interface doesn't give you a view of the SPAM folder without expanding the view.
« Last Edit: May 28, 2010, 09:59:35 AM by 1995yj »
Complete Loser
« Reply #13 on: June 11, 2010, 11:23:04 AM »
thank you 95yj. That looks like its gonna be it. I dont 'directly' have gmail. and i use outlook express.
Buuuuuut, the company i go though does use gmail. so i have to get on their site, and change these settings it looks like.
Idiots! I NEVER use a spam filter just for this reason.
Now if i can figure out how to turn this crap off.
