Author Topic: Drivability issue  (Read 5864 times)
Offline Trainman638
Drivability issue
« on: May 21, 2010, 04:39:45 PM »
I'm having issues with my Mule (95YJ 2.5 125,000 miles). It starts and runs fine until it gets warmed-up then it feels like it's missing. An intermittent miss? Is that even possible? I've recently added elec. cooling fan, 170amp Alt, 19lb injectors, removed air box restriction, 4.0 TB, Accel coil and wires and new plugs gapped to .060. Since it still has the factory exhaust, I was thinking maybe the cat? Any help would be greatly appreciated.   :puzzled:
95 YJ 2.5/ax5/np231. 4" superlift, 33" MT's, 4.0tb, 136amp alt, 19lb injectors, electric fan, smittybilt 8k winch, custom bumpers and rock sliders, rhino'd tub, header and ceramic coated exhaust.
67 M416 trailer painted to match.
96 XJ 4.0/ax15 My wife's Jeep and my new project.
Re: Drivability issue
« Reply #1 on: May 21, 2010, 05:04:02 PM »
Could be the cat, but I am wondering if the Accel coil can handle the .060" gap as well...  I used to have that one, and I dont remember it handling such a gap.
Offline Trainman638
« Reply #2 on: May 21, 2010, 05:19:00 PM »
If the coil could'nt handle the gap, would'nt I have had this problem since I installed it? Or on start-up?
« Reply #3 on: May 21, 2010, 05:23:25 PM »
why would you gap to .060 with stock ignition? - yes, that can be a problem (not saying that is the case but use stock gap instead to eliminate the possibility)
Offline Trainman638
« Reply #4 on: May 21, 2010, 05:27:52 PM »
It's a 40,000 volt coil.
« Reply #5 on: May 21, 2010, 05:49:22 PM »
Can you feel it miss?
Offline Trainman638
« Reply #6 on: May 21, 2010, 05:56:36 PM »
Yes, I can feel the lack of power on the road and I can feel the motor struggle. It sure feels like a miss to me. BTW: I just pulled my plugs. They look good. Gap is set to .050, NOT .060 as I said earlier. As I recall, I chickened out going all the way to .060.
« Reply #7 on: May 21, 2010, 06:03:18 PM »
But it's not a sudden lack of power?  If it's an intermittent lack of power then that would suggest a misfire.  This usually happens more when you rev it higher.
Overall lack of power would more then likely be something else.
If you think it might be the cat then remove it and look inside.  You should be able to see if there is any damage.
« Last Edit: May 21, 2010, 06:04:12 PM by Jeffy »
Offline Trainman638
« Reply #8 on: May 21, 2010, 06:15:25 PM »
Power is fine (for a 2.5) until it warm up. Once it's warm it misses or stumbles. If I shut it off, and restart with the engine warm then it misses at start-up. Thanks for the help, I'll pull the cat tomorrow.
« Reply #9 on: May 21, 2010, 07:17:14 PM »
ah, i missed the Accel coil part
« Reply #10 on: May 21, 2010, 07:27:32 PM »
That doesn't sound like a exhaust issue.  Maybe fuel pump going bad?  Can't be vapor lock.
Offline Trainman638
« Reply #11 on: May 21, 2010, 08:01:13 PM »
Fuel pump? Only when the engine is warm? How would that be possible? I'm learning as I go. ::)
Offline Trainman638
« Reply #12 on: May 21, 2010, 08:25:03 PM »
Maybe a stuck injector? Bad injector? More things to check....this is that "learning curve thingy" ain't it? I wear my noob badge with honor :pirate:
« Reply #13 on: May 21, 2010, 08:59:08 PM »
sometimes the pump gets hot in time too, so that might be the cause but i wouldn't rule out the cat
same goes for the coil though, once it gets hot you might get misfires - but the misfires are pretty distinct, so far sounds like you're losing power rather so that should point to fuel or exhaust or anything related to that (including sensors).
copperyj
« Reply #14 on: May 22, 2010, 07:54:53 AM »
Mine did that.  Would start up just fine.  I would leave my house on the way to work, and I'd get about 1 mile away, and it'd start to miss and sputter.  Seemed like the more throttle I gave it, the worse it got.  My problem was the Crank Position Sensor.
My jeep is a 93, 2.5L w/ around 200k miles.
