Author Topic: new radiator  (Read 2010 times)
melbill
new radiator
« on: June 24, 2010, 02:32:45 PM »
I just got a new all aluminum radiator for my YJ. I have a manual and when the radiator arrived it is for an auto. Should I plug the holes for the transmission lines, or can I use then as an oil cooler, run a bypass off by bottom radiator hose and get the coolant cooled further, or is there something else I can do to utilize this?
Thanks a lot,
Bill
Re: new radiator
« Reply #1 on: June 24, 2010, 02:35:34 PM »
Thanks a lot,
Bill
you don't need to plug them, they are connected to an internal tube and it is separated from the water circuit (what i mean is that coolant will not come out thru those holes, they are meant for the transmission fluid).
Re: new radiator
« Reply #2 on: June 24, 2010, 02:52:39 PM »
They are usually plugged anyway.
Re: new radiator
« Reply #3 on: June 24, 2010, 04:29:34 PM »
You could use it to cool your power steering.  That's what I plan to do with mine (not yet installed).
melbill
Re: new radiator
« Reply #4 on: June 24, 2010, 05:45:59 PM »
Thank you all for your quick replies. I had not thought about about running power steering fluid through it. Am I right in figuring that I would just adapt the low pressure line into the radiator then a line out into the pump? Also would I have to make the fluid run in one direction or the other (I don't know which way stock is but I am sure I can find it).
Thanks again,
Bill
Re: new radiator
« Reply #5 on: June 24, 2010, 07:24:18 PM »
Yes, low pressure.  You wouldn't want to run high-pressure though there.  I don't think it would matter which way you go but it would probably be better to keep the hot side short.
