Author Topic: Dana 35 woes  (Read 2494 times)
RT
Dana 35 woes
« on: August 27, 2010, 11:54:28 PM »
so i just had my rear diff rebuilt and now instead of a grinding howl at above 20 miles per hour I get this weird ghostly whine while accel and floating but not while decel. If you don't mind me asking, wtf is this *%*@
Re: Dana 35 woes
« Reply #1 on: August 28, 2010, 01:40:45 AM »
Sounds like maybe an incorrect gear mesh setup.  Who did the gear install?
Re: Dana 35 woes
« Reply #2 on: August 28, 2010, 06:50:47 AM »
+1
are they new gears?
did you do it your self?
do you know how to check tooth contact pattern?
« Last Edit: August 28, 2010, 06:56:03 AM by Torch_Ind »
RT
Re: Dana 35 woes
« Reply #3 on: August 28, 2010, 09:34:56 AM »
wheel align it alb did it...they said I shouldn't worry about it, but it's extremely annoying...i was going to take it to 4 wheel parts and have them check it out.
RT
Re: Dana 35 woes
« Reply #4 on: August 28, 2010, 09:36:51 AM »
I have new spider gears, and I can't remember what the things called...it's what the spider gears are housed in and the ring gears bolted to
Re: Dana 35 woes
« Reply #5 on: August 28, 2010, 09:51:27 AM »
Carrier.
There shouldn't be much if any noise. Something sounds messed up.
Clem
Re: Dana 35 woes
« Reply #6 on: August 28, 2010, 03:51:44 PM »
If you are in Albuquerue, pm me. It coulb someting stupid like low gear oil if it was just rebuilt...
RT
Re: Dana 35 woes
« Reply #7 on: August 28, 2010, 05:01:57 PM »
Redline mt-90 should I put it in my tranny or no? Is the GL5 really that bad for my brass sinchros, will I be helping things out or will I just make things worse with the redline
Re: Dana 35 woes
« Reply #8 on: August 28, 2010, 05:18:19 PM »
That is what I put in mine. So far so good.
Re: Dana 35 woes
« Reply #9 on: August 28, 2010, 08:55:22 PM »
the only other thing other then gears making the noise to me is you have one flat tire and it's making the spiders spin fast but other then that I honestly think it's your ring and pinion making noise. you may have bad wear on it from whatever went before that you had repaired.
RT
Re: Dana 35 woes
« Reply #10 on: August 29, 2010, 12:24:34 AM »
it went into the shop for fried spiders, came out ok but the carrier was walled out, put a new one in....suddenly makes tranny noise...I check the tranny fluid, it's way light and runy. Which is funny because I checked it before it went in and it was fine. I think I must be dealing with a crooked shop  ???  But anywho, it drives great and the diff that they worked on isn't getting hot at all...
