Author Topic: How fast can you strip a Jeep and put it back together?  (Read 1824 times)
« on: September 09, 2010, 01:20:42 PM »
<a href="http://www.youtube.com/v/gD78rTF0Rjo?fs" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/gD78rTF0Rjo?fs</a>
Not sure I would take it on a long trip or go wheeling with it the way they have everything finger tight. But pretty cool.
Re: How fast can you strip a Jeep and put it back together?
« Reply #1 on: September 09, 2010, 01:46:11 PM »
Cool, but I agree.  Everything is made to come off.  The hood had dosconnects and there were no inner fenders, no glass, etc...  The body is just sitting on some mounts.  No front driveshaft and the rear has some sort of simple setup that doesn't need bolts.  No transfer case either.  Notice, there is no gas tank and no coolant in the radiator.
I think they should use a barn find CJ-5 and try it again.  I'm sure it will take a bit longer.  :lol:
« Reply #2 on: September 09, 2010, 01:52:35 PM »
Pretty cool.  At the end it looks like they avoid turning the tires too much or maybe they are limited by something.
« Reply #3 on: September 09, 2010, 02:00:52 PM »
Limited to having it fall apart  :lol: There was not much holding it together.
« Reply #4 on: September 09, 2010, 02:16:07 PM »
Turning the wheels puts a lot of lateral stress on the lugs.  So if your  lugs are hand tight it will cause them to loosen up.  Although, if they're tearing it down every 100yrds it won't matter much.
