Author Topic: What's your favorite gear?  (Read 3764 times)
« on: October 01, 2010, 08:16:06 PM »
Mine is 3rd.   :lol:
Re: What's your favorite gear?
« Reply #1 on: October 01, 2010, 08:39:45 PM »
what about reverse  :puzzled:... i went with 3rd good gear on-road to make it seem as though  there's power under the hood.. although I use 2 (or 1st)more than 3 off road...
littledavid123
« Reply #2 on: October 01, 2010, 09:17:53 PM »
High mountain dirt road, a cooler full of beer, bucket of chicken and all in second gear...How could it possibly be better?
b.hog
« Reply #3 on: October 02, 2010, 09:06:37 AM »
3rd also.Its a good gear for deep muddy roads(4L)will save your clutch,also I use 3rd alot when on bumpy side roads 20 -30 mph.flows through the bumps better than if in 2nd (throttle response from foot hitting accel every bump)
« Reply #4 on: October 02, 2010, 11:27:40 AM »
6th
but only have a 5 spd :lol:
« Reply #5 on: October 02, 2010, 11:30:21 AM »
all of the above
« Reply #6 on: October 02, 2010, 03:36:00 PM »
First, since that is pretty much what I do most of my rock crawling in
« Reply #7 on: October 02, 2010, 08:53:49 PM »
2nd here (assuming it's for wheeling).  Low enough to have power, high enough to clean the tires.
« Reply #8 on: October 03, 2010, 08:14:24 AM »
Tranny = 1st
Klune = low
T-case = high
This is the set up I use most.
« Reply #9 on: October 04, 2010, 08:59:17 AM »
Second (in 4L) because I consider it to be a "secret weapon".  Many times an obstacle that was tough in first becomes easy by just trying it in second instead (mostly hills and low traction ledges, not so much on rocks).
C.Redbeardd
« Reply #10 on: October 06, 2010, 01:17:31 PM »
Granny gear on the rocks. Mine only goes to 4th, but I would love an overdrive on the highway. :(
Offline Eucalypta
« Reply #11 on: October 06, 2010, 03:38:23 PM »
3rd driving around town, 2nd off road in 4Lo.
1st in both Lo and Hi, I try to avoid because of the sensitive throttle.
1994 YJ 2.5L - 1996 ZJ 5.2 V8
Offline VA_YJ
  • Now I need a CJ...
« Reply #12 on: October 08, 2010, 02:55:05 PM »
My favorite gear is reverse.  It's used to back out of the garage, driveway, parking spot or off a trailer.  It's the gear that starts all the fun!  It's also great for extracting your a$$ when you are having trouble with any of the other gears.  It's the lowest ratio gear (assuming you're running an ax-5), so you get lots of torque.  It even has a lock out to prevent you from using it when you don't want to! Jeffy didn't even include my favorite gear on the picklist. :'(
« Reply #13 on: October 08, 2010, 03:22:15 PM »
No Retreat!  :lol:
