Author Topic: Jeep swerves when shifting  (Read 8375 times)
Re: Jeep swerves when shifting
« Reply #15 on: October 16, 2010, 06:29:22 PM »
I think it may be a little bit of the lockers and steering as well. So, a drop pitman arm and trackbar relocation bracket? I'll check around for some good prices. I plan on getting a new lift here soon. This one is tweaked a bit. The driver side front shackle is leaning to the driver side. The shackle isn't bent and the bearings are good. So I think some how I warped a spring.
I have a brand new drop pitman arm from a lift kit that i didn't use if you're interested
EDIT: here, there were no takers so it's still available http://4bangerjp.com/forums/index.php/topic,7684.0.html
« Last Edit: October 16, 2010, 06:30:56 PM by sharpxmen »
« Reply #16 on: October 16, 2010, 07:26:24 PM »
If you have a locker then it's the locker.
« Reply #17 on: October 16, 2010, 07:31:44 PM »
The reason for bumpsteer is not because your drag-link and track bar aren't parallel.  That just causes binding when they move in different arch's.  The reason for the bumpsteer is because the drag-link is not parallel with tie-rod.
Looking at his setup, he'll need to raise the track bar on the axle side to get it parallel with the drag-link.  If he lowers the drag-link with a pitman arm, it will be even more out of parallel.
Still, if he's got a locker then it's the locker...  You've got to learn to shift when you're going straight and not while in a turn.
« Reply #18 on: October 16, 2010, 08:54:33 PM »
that's pretty much what i said but if you look at it he won't have room to raise it by just that little. You still have side to side movement in the front if you have that angle steep (even with them parallel), should be closer to horizontal though so the difference in side to side is not that significant when loading and unloading the front.
lqdtrance
« Reply #19 on: October 16, 2010, 09:56:55 PM »
So I should be good if I get the drop pitman arm and the bracket correct? Or just keep it as it is? Either way, I'm interested in that Pitman arm.
« Reply #20 on: October 16, 2010, 10:46:02 PM »
Well, first off does you Jeep have a suspension lift?  It's hard to tell in the pic.  If it's on the stock leafs then just take off the track bar and install the dropped pitman arm.
It looks like you're using the stock track bar location with some lift.  I can't tell if it's all shackles or not.  If there is a suspension lift then your front and probably rear axles are not running centered to the frame.  Although if you have a lift then there is a good chance it already has a dropped pitman arm.  In which case you would just need to get rid of the track bar all together or raise the mount on the axle side.
If that's not the case then I don't think you'll b able to raise the track bar sufficiently if you get a dropped pitman arm.  So the best option would be to get rid of it.  Hopefully you have already removed the rear track bar.
lqdtrance
« Reply #21 on: October 17, 2010, 06:20:34 AM »
I have a suspension lift with shackle lift. Superlift springs. I think 3" and 1" shackles. Both track bars are on front and rear. I honestly do not think they are running center. Is there a way to correct this problem while still being able to have the track bar for stabilization? I just want it safe but still be able to out in the woods. Right now it doesn't feel safe at all.
« Reply #22 on: October 17, 2010, 07:19:34 AM »
The rear one I doubt you'll notice it's gone; even my RE lift kit said in the instructions to get rid of it.  I never have noticed any difference.  And if I were to do it all over again, I would also get rid of the front one.  I currently use a telescoping one from JKS, but I doubt it's working as it should (it's closer to not having one, I think).
lqdtrance
« Reply #23 on: October 17, 2010, 07:32:46 AM »
Funny cause I just put the damn track bar back on in the front after I got extended sway bar connectors. Sway bar/track bar are the same thing correct?
« Reply #24 on: October 17, 2010, 09:27:17 AM »
trackbar is the one going from the driver side part of the frame to the axle on the passenger side (right above the axle vacuum disconnect) - it keeps the axle from moving side to side
Offline Eucalypta
    • Eucalypta Oud-Hollands Snoepgoed
« Reply #25 on: October 17, 2010, 09:38:54 AM »
How long ago was the suspension lift installed? Did you retighten the U-bolts?
Further more: I got rid of the rear trackbar. A friend of mine reinstalled his, when pulling a trailer he lacked stability.
Mine front trackbar got a 2" bracket, raising the trackbar at the axle side. It was part of my liftkit. Never driven it without front trackbar.
To Boldly go where no one has gone before - James T Kirk
1994 YJ 2.5L - 1996 ZJ 5.2 V8
« Reply #26 on: October 17, 2010, 10:10:10 AM »
The front and rear trackbars are mounted in opposite directions, so when you lifted without installing trackbar brackets the axles were pulled in opposite directions.  The rear axle no longer tracks directly behind the front axle.  When the jeep leans forward or back during acceleration/braking, this misalignment of axles is even greater as the suspension movement causes the axles to be pulled sideways.
I'd remove both front and rear trackbars and drive the jeep, see if it still pulls during acceleration/deceleration.
lqdtrance
« Reply #27 on: October 17, 2010, 05:53:25 PM »
Ok. I'll do that and see how she is.
I know there is an extension for the track bar on the rear. I also did a measurement from the inside of the wheels and all around the passenger side is 1 - 1.5:" closer to the frame then on the driver side.
My lift is old actually. Looking at 5-6 yrs old maybe. I am due for a new one. Unfortunately I don't have the beans to do it all yet. I am a full time student once again.
« Reply #28 on: October 17, 2010, 09:56:11 PM »
Age doesn't really matter too much.  With the older lifts that are stuff, they usually soften up nicely when aged.   :lol:
« Reply #29 on: October 17, 2010, 09:58:58 PM »
Between the sagging of older springs, and the seizing of shackle bushings, it's hard to say if your ride is stiffer or softer than it should be in like-new condition.  Be sure to post back the results of any attempted diagnosis.
