Author Topic: Flowmaster 40 with a turn down  (Read 4231 times)
Re: Flowmaster 40 with a turn down
« Reply #15 on: October 22, 2010, 05:45:08 PM »
meh perhaps a turndowns worth a shot
I think you will be more bothered by the loudness of it then fumes with a flowmaster muffler
RT
« Reply #16 on: October 23, 2010, 02:45:54 PM »
ok, just picked up the delta 40, bout to bolt it on an see what it's like?
RT
« Reply #17 on: October 23, 2010, 03:52:46 PM »
ooootay, anyone know an easy way to unbolt your muffler without dropping your skid or cutting  :brick: :brick: :brick: :brick:
« Reply #18 on: October 23, 2010, 04:21:22 PM »
Unbolt the U clamp.  Then you usually have to heat up the joint with a torch and pound it off.  Otherwise cut the muffler off close to the case so you're not cutting the cat's output.  Then banana peal the muffler pipe off the cat.
If your cat is bolted on then it will be easier to remove the whole cat and muffler together.    More then likely you will need to cut the pipe off the output of the muffler to get it out anyway.
Offline aparke4
« Reply #19 on: January 01, 2011, 02:19:12 PM »
dont do it
even on a 2.5 it is loud and obnoxious
trail only rig? yeah sure i can see that... but for a DD not worth it
hell my exhaust is loud going out the rear! turbo muffler and hi flow cat on 2.5 w/ softop...
