Author Topic: yj power steering  (Read 1947 times)
lqdtrance
yj power steering
« on: November 13, 2010, 07:44:02 AM »
I want power steering. I ended up pulling all the steering components off of a 1990 cherokee. If I buy the correct mounts and correct hoses, will it work?
Re: yj power steering
« Reply #1 on: November 13, 2010, 08:05:22 AM »
The pump and box are the same, but you'll likely need the YJ brackets to mount the pump.
lqdtrance
« Reply #2 on: November 14, 2010, 07:16:10 AM »
Cool, all I needed to know, thanks. Off to look for YJ brackets.........
« Reply #3 on: November 14, 2010, 12:03:29 PM »
I'm not sure but I might have one.. depends if last clean up it got tossed
lqdtrance
« Reply #4 on: November 15, 2010, 08:40:07 AM »
Let me know. I haven't found any yet. Surely I can get them at the junk yard though.
lqdtrance
« Reply #5 on: November 28, 2010, 06:57:42 AM »
No luck with any of the local Junk yards. I can get most of the parts from the dealer but they can't get one of the brackets. Still looking around if anyone has any to get rid of.
« Reply #6 on: November 29, 2010, 12:57:53 PM »
Check here: www.car-parts.com
You could also source parts from a 2.5L Dodge Dakota.  A Dakota steering box is a common swap for a YJ/TJ box as well.  I would think an XJ would be easy.  You should also be able to get parts off a 4.0L (XJ, ZJ, MJ, TJ, etc...) as they should use the same brackets.  I forget the exact year but in the 2000's when they switched things around on the engine so a bracket off one of the late models might not work.
lqdtrance
« Reply #7 on: December 01, 2010, 06:05:30 AM »
Good to know. I got the power steering off an 89-92 cherokee sport, 4.0. The brackets would work but the bolt holes don't line up. I'll check out that site, Thanks.
« Reply #8 on: December 01, 2010, 08:22:25 AM »
can't remember for sure but i think the Cherokee had a different offset on the pulleys, might want to check that to make sure the belt is tracking properly (could be different years but i remember running into that issue at some point when i was scavenging some parts)
