Author Topic: Re-gear prices  (Read 7446 times)
Offline stan98tj
  • Wheeling New England
Re-gear prices
« on: November 16, 2010, 07:15:07 PM »
Got my tires. now to look at my regear options. Not many shops here in CT, i was able to reach one this afternoon and the guy quoted front and rear regear at about $2300. This seemed kind of high, and is out of my price range for now. Is this what i should be expecting? He also advised i should gear to 4.10 given my 3spd auto.
Offline aw12345
    • my jeep picture page
Re: Re-gear prices
« Reply #1 on: November 16, 2010, 07:58:33 PM »
parts would run you about 500 bucks, 600 at the most so yeah quite expensive.
1800 bucks for labor is pretty high at a 80 dollar hourly rate they would have to charge you for about 22.5 hours labor to set up 2 axles. On average it would take no more than 5 hours an axle at the most. Some take 2 hours or so if you are lucky and get it right the first time.
I regear axles out of the jeep for around 200 bucks labor a piece as a hobby
2006 Jeep Wrangler TJ SE
2004 Jeep Wrangler TJ SE
Re: Re-gear prices
« Reply #2 on: November 16, 2010, 09:23:42 PM »
If you're going to go with 4.10's then you would be better off spending the money on two complete axles from a 4banger manual.  Should be around $5-700, I'd imagine.  Then you would have a spare set.
If you go to 4x4 shops, I'm sure won't find anyone for under $1500.  Try speed shops that work on race cars.  They do gears all the time and should be able to get it done for less then $2300.  If you pull your axles, they might even cut you a deal.  You might have to supply the gears but it's not a big deal.  Shop around for gears as well.  Spicers are usually more expensive then Yukon, Superior or anyone else.  Make sure you buy decent master install kits.  Ones that come with carrier bearings.
It's been a while since I bought my gears but I bought Spicer 4.56's with Yukon Master install kits for $416.  That's with a 7.25% sales tax too.  IIRC other brands were close to $100 less.
drunkencityworker
Re: Re-gear prices
« Reply #3 on: November 17, 2010, 03:54:01 AM »
410 should be ok if you stay on 31s. 33s you would want 456 bc of the auto. Jesse James runs 456 and has auto. He runs 33 on street and has 36 for the trail. in chicago the going rate for a mechanic doing it on the side is bout 300 an axle labor. Personnely I put a 5.2l in for about 2g and I was down for 4months. I am not bashing but doing 75 at 1700 rpms is sweet :weee:. To be honest there was a few times over the summer I was kicking myself for not just regearing. In the end I am happy with it know but I sacrificed a whole summer worth of wheeling
knotts89
Re: Re-gear prices
« Reply #4 on: November 17, 2010, 07:34:36 AM »
when i got my gears done front and rear they said it called for 12 to 14 hours of labor i think all together with parts and labor it ran between 1500 and 1600
Offline stan98tj
Re: Re-gear prices
« Reply #5 on: November 17, 2010, 10:49:25 AM »
i called another place and was estimated around $1800...an improvement over $2300. the reason i guess the first guy wanted to do 4.10 was so he could put a Ford rear end in the jeep. I want to put a locker in the front, and he said it was a waste of $$ as i wont improve traction much if at all. he said to put the locker in the rear-and that meant looking at a different axle-hence, the ford.
Id like to put the locker up front, what do you guys think. Id only do it if i can get the re-gear done for 1500 or less. If you guys think the same as him, that a locker up front isnt gonna do much then maybe i ought to reconsider.
drunkencityworker
Re: Re-gear prices
« Reply #6 on: November 17, 2010, 11:32:49 AM »
I have a locrite in front and love it. You will have noticably improved traction with it up front. My rear is 8.8 w lsd. But locrite went in first.
Re: Re-gear prices
« Reply #7 on: November 17, 2010, 03:05:36 PM »
i know quite a few people that went front locker before rear. i went rear locker then added the front and found that when i only had the rear locker if i wanted to play in the rocks the front had a tendency to have a tire come to a big rock stop and the back push the jeep making it pivot about that rock which isn't fun in some (most) situations. i would assume by doing a front locker you wouldn't have that problem if you only have 1 locker.
Offline stan98tj
Re: Re-gear prices
« Reply #8 on: November 18, 2010, 06:30:05 AM »
i figured i would just lock the front since i only wanted to spend $$ on one locker..and i keep reading the d35 doesnt like to be locked esp with larger tires. figured i go up obsticles front way first so a fwd locker should help. Just wanted to know what you guys thought about that. So basically ill be goin to 4.56 and should expect the job to cost about $1600. I read somewhere online (maybe jeepforum) ppl getting it done for $800-1000. why cant i be so lucky lol.
how will the jeep drive, by the way, with the 4.56 gears? faster? slower? suck down more gas?
Offline k
Re: Re-gear prices
« Reply #9 on: November 18, 2010, 07:23:48 AM »
A few years back when I had money to put into the Jeep, I had ARB's installed front and rear when I regeared.  Made a big difference when crawling.  With the lockers I was able to creep where others took the "heavy foot" option.  I did put 4.10's in when I regeared, but have regretted going with those.  Would like to gear again with 4.56 or 4.88's.  Not sure which ones yet, but I too run an auto.  The 4.10 were an improvement, but with 33's, they weren't enough.  Think I can get more power on the road and better gas milage with another gear change.
1995 2in pucs, 2.5 suspension, 33 BFG's, 4.0 TB, TBS, Auto w/ TCI shiftkit, header, flowmaster, Jacobs Ignition, ARB's front and rear, Rock-it tube w/K&N filter, SYE kit.
Monkeypants
Re: Re-gear prices
« Reply #10 on: November 18, 2010, 03:04:48 PM »
I hate to see you getting quotes for that much... keep looking!
http://www.rockyour4x4.us/index.php?page=shop.product_details&flypage=shop.flypage&product_id=12&category_id=4&manufacturer_id=0&option=com_virtuemart&Itemid=29
Link included only for reference.  I've not had my tj regeared, but I've been told that its 1000 to 1200 in my area (E. TN).  Above link is for 1150, though there is no listed info on if that includes gears (not likely), and that a 500mi follow up service is not included in that price.  By the way, that was the first regear price I even checked in my area, so I'm guessing I could find better if I dug.  Good luck!
Offline stan98tj
Re: Re-gear prices
« Reply #11 on: November 18, 2010, 04:39:05 PM »
im gonna keep calling around but i dont think it will get any better than $15-1600. im prob gonna have to hold off on the locker for now.
rdtj
Re: Re-gear prices
« Reply #12 on: November 19, 2010, 12:51:32 AM »
You should make friends that are mechanics like me then they will do it for free!!!!! :dance: :spam:
Offline stan98tj
Re: Re-gear prices
« Reply #13 on: November 19, 2010, 09:28:11 PM »
Ive been wondering about something concerning the regear. According to the charts i will be at about 3k rpm at 65 if i regear to 4.56.  What i want to know is will the jeep be pushing hard at this speed? is going to be howling at 3k?  When im driving along and start to go uphill and i want to maintain a certain speed the jeep spools up to 3k and accelerates but you can hear the engine has a load on it. it pretty much howls. If im on a flat stretch though, i can cruise to 70 mph and it will climb to about 3k but it isnt pushing hard so it's not screaming. Im wondering if the engine will be strained and howling at 65 or reach that speed easily and not be screaming.
Re: Re-gear prices
« Reply #14 on: November 19, 2010, 11:39:06 PM »
No.  For a vehicle that doesn't have a OD, 3000 RPM is pretty normal for 65MPH. If you're not using to using the whole powerband, 3000 RPM might seem high.  I'd say 3700 RPM is getting high and over 4000 would be screaming.  If you drop below 3000 too much, the Jeep will struggle to stay at speed.
