Author Topic: window heat  (Read 2007 times)
minespath
window heat
« on: December 31, 2010, 08:51:05 AM »
have no heat out of window vent ,other than the two upper dash vent  when i slide the control over ,same thing in summer ,i hear it blowing and like i said the dash upper vents work fine any ideas ,its a 97 with no a/c
Re: window heat
« Reply #1 on: December 31, 2010, 11:00:34 AM »
not sure about 97 tj's if there vacuum or cable design
the yj's were famous for the cable seizing or falling off somewhere
Re: window heat
« Reply #2 on: December 31, 2010, 12:55:18 PM »
i think they're vac actuated but don't bet on it.
Re: window heat
« Reply #3 on: December 31, 2010, 02:34:12 PM »
if there vac i would check for vac leak or something just inop
st.chevrolet
Re: window heat
« Reply #4 on: December 31, 2010, 04:03:46 PM »
They are vac actuated on TJ's, and the little plastic levers are notorious for breaking my dad has replaced his twice. I do not believe you can buy just the levers from the dealership either.
Here's what you need :
http://www.omix-ada.com/jeep-parts/subCategory.asp?parent=2552&itemIndex=51#itemList
« Last Edit: December 31, 2010, 04:07:05 PM by st.chevrolet »
Re: window heat
« Reply #5 on: December 31, 2010, 04:41:41 PM »
+1.  They seem to be a real problem with the TJ's.
