Author Topic: Bigger tires.... lower gears.....MPG?  (Read 2111 times)
bigbrad_4x4
« on: February 19, 2006, 09:34:28 PM »
Hey guys, I just got a '03 TJ SE and I wanna go with some bigger tires, at least 31's.  I'd like to go with 35's, and if I swap in the proper axle ratios, would I still be gettin the same gas mileage, or would it change, and if so, how much should it?
Thanks.
« Reply #1 on: February 19, 2006, 09:52:27 PM »
Well it migth be best to look arround the FAQ and search a bit.
The Faq on gearing would be a start.  Then check out the Dana 35c in the FAQ.  That should get you moving in the right direction.
